Symmetrical geometry and parameter settings generate asymmetrical mesh in Gmsh.
Old   September 3, 2021, 00:18
Default Symmetrical geometry and parameter settings generate asymmetrical mesh in Gmsh.
shenjian
SJ2050 is on a distinguished road
I had a 2d symmetrical airfoil and set symmetrical parameters on the upper and lower surface. Then, I generated the 2D mesh in Gmsh, but I found the upper and lower mesh were not symmetrical, but I couldn't find the problem. I appreciate your help.
I post .geo file to the attached file.
SJ2050 is offline   Reply With Quote
gmsh, mesh
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
