Solution is diverging (Only the continuity equation)
Old   March 2, 2022, 05:36
Default Solution is diverging (Only the continuity equation)
Nitish Kumar
Nitish the Beast is on a distinguished road
Hii, I'm trying to simulate a sloshing problem in which I'm applying Acos(w*t) velocity in the x-direction at the bottom surface of the cylindrical tank having water at the base and the top is filled with air and open to the atmosphere. For this, I applied dynamic mesh (Layering option ) only by using UDF as shown below. the problem is my solution is diverging especially the continuity equation. Can anyone suggest me what should I do?
UDF:
#include "udf.h"
static real velx =0.0;
DEFINE_CG_MOTION(bottom,dt,vel,omega,time,dtime)
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
velx =0.012566*cos(6.28*time);
vel[0] = velx;
Message ("time= %f, vel[0]=%f\n", time, vel[0]);
Relaxation factor:
Pressure-0.6
Density-0.8
Body force-0.5
momentum-0.4
volume fraction-0.6
Suggest me something.
Thank you.
Nitish the Beast is offline   Reply With Quote
dr amine, rob
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
decompose dependent solution arionfard OpenFOAM 3 December 10, 2018 09:36
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
