Wind Blade Serration Meshing Error
Old   April 21, 2022, 03:45
Default Wind Blade Serration Meshing Error
Chehade
Chehade is on a distinguished road
Hello, i am trying to simulate the 6DOF rotation of a serrated edge wind turbine, i have drawn my turbine on solidworks and imported to ANSYS. When i use watertight geometry i get an error at eh 'generate volume mesh' (i am using tetrahedral) that says there are gaps that must be filled or refinned. However, it highlights the serration which i purposely want to remain on my blades. Is there any way to fix without having to remove the serrations? Or at least modify their geometry. Kindly find below the serration pictures.
Chehade is offline   Reply With Quote
Old   April 21, 2022, 10:46
Kira
aero_head is on a distinguished road
Imported into ANSYS what? That’s kind of like saying you made the part in CAD and need help with something software specific.
aero_head is offline   Reply With Quote
Old   April 21, 2022, 10:50
Chehade
Design modeler. The turbine is drawn in ansys design modeler then imported to solidworks for adding serration. Then re-imported to ansys design modeler for enclosures and boolean finally to mesh.
Old   April 21, 2022, 10:51
Chehade
I know ansys has problems with sharp edges but the whole point is having that sawtooth pattern so is there a workaround.
Old   April 21, 2022, 10:54
Kira
Have you seen this video? It’s from the ANSYS company
https://youtu.be/S_kpYzsqzo0
Old   April 21, 2022, 10:58
Kira
You can also try reducing the defeaturing tolerance, it should be less than the smallest details on your geometry.
Old   April 21, 2022, 11:11
Chehade
I have tried to repair but it states that it failed. As for the 2nd option i do not know how and where
Old   April 22, 2022, 09:43
Chehade
***Bump***
design modeler, error, mesh, serration, wind turbine
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
