Connection of two simulations cases
Old   May 9, 2022, 07:51
Default Connection of two simulations cases
Březňák
breznak is on a distinguished road
(please see the attachment)
I want to use the velocity field at case 1 outlet as the velocity-inlet at case 2 inlet.
For the simulation of only case 1, which boundary condition for outlet should I use? It should be fixed mass flow rate?
Case 1 and Case 2 are geometrically connected, so I think pressure outlet with 0 Pa for case 1 simulation is wrong.
Regards
Breznak
breznak is offline   Reply With Quote
Old   May 10, 2022, 14:28
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I generally hate when this happens, but I have to ask you to give use some details about your general problem. What is, actually, the end result that you want to achieve? What is impeding the simulation of both domains together?
This is because the approach you are asking about is wrong in general. So we need to know the larger context to maybe rationalize the wrong answer that works in your case
sbaffini is offline   Reply With Quote
decomposition of multi domain cases for large simulations romant OpenFOAM Pre-Processing 6 May 10, 2023 21:27
Unphysical Results of Low-Re Airfoil Simulations ericthefatguy SU2 2 February 2, 2015 05:07
Question on running CFX simulations in workbench parameter set table Anna Tian CFX 0 September 20, 2014 01:51
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 01:31
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 14:10
