January 19, 2024, 12:24 |
Odd behaviour of the length
Matthew
Rep Power: 4 |
I am examining a 1D rod using mass co-ordinates under the effect of gravity. I have the rods on their end so that gravity will assist it. The equations are specific volume and u, the velocity. The mass co-ordinate is given by:
The equations are then: I'm unsure about what should happen. For the application, the length should monotonically decrease. Do you have any idea what's going on? Code:
%this code solves the following system of equations: %v_t=u_h %u_t=(zeta/v*u_h)_h %dX/dt=u %h is defined by h_x=1/v, and X is the new position of the interfacial %points %The boundary conditions for u is u(t,0)=0, u_h(t,1)=-v(t,1) %The BC's for v, can be derived from ones on u. %here u is the velocity, and v is the specific volume defined as 1/rho, where rho is the density %The system is in conservative form, and the finite volume method is the best method for these types of equations clear;clc; S=struct; %---define physical constants N=200; %This is the number of cells in the simulation S.N=N; S.alpha=0.2; c_p=1; %heat capacity. rho_half(1:N)=0.6; %This is the initial density eta_0=0.005; S.eta=eta_0; M=300; %This is the number of points in the time domain. %---Set up geometry x=linspace(0,1,N+1); %Initial spacing of the cell interfaces and ends. dx=x(2); %initial lengths of cells t=linspace(0,300,M); % This is the time of integration L=zeros(M,1); %The length of the of the piece L(1)=1; %Initial length dt=t(2); %time increment S.dt=dt; mu=dt/dx^2; %---Set up of variables nu=zeros(M,N); %The specific volume =1/density u=zeros(M,N); %The speed of the material X=zeros(M,N+1); %The position of cell interfaces X(1,:)=x; %---The solution of the system will be done via Newton-Raphson. The two %variables v and u will be put into one vector y=[v u]' y_old=zeros(1,2*N); %This is the initial vector used. nu(1,:)=1./rho_half; %Initial specific volume y_old(1:N)=nu(1,:); %v(1,:)=y_old(N+1:2*N); theta=0.5-1/(12*mu); %This will meximise the timestep. rho_0=zeros(1,N+1); %This sets up the calculation for h to begin with. %This interpolates the density from the cell centres to cell boundaries. rho_0(2:N)=0.5*(rho_half(1,N-1)+rho_half(2:N)); rho_0(1)=1.5*rho_half(1)-0.5*rho_half(2); rho_0(N+1)=1.5*rho_half(N)-0.5*rho_half(N-1); h=cumtrapz(x,rho_0); %calculates h, which is used throughout the timesteps. nu_m(1:N)=1; %This is the matal powder density, the maximum possible density. S.nu_m=nu_m; dh=diff(h); %This is used to approximate the derivative S.dh=dh; tol=1e-5; %Tolerance on the Newton-Raphson method. dx=diff(x); for i=2:M y_init=1.001*y_old; %This is an initial guess for the new solution forbased upon the previous timestep solution y = Newton(tol,y_old,y_init,theta,S); %call the Newton Raphson routine nu(i,:)=y(1:N); %First N entries are the specific volume u(i,:)=y(N+1:2*N); %the second entries are the velocities %Compute the new grid dX=dh.*nu(i,:); %The mass in each cell in constant, use density*length=mass to compute the new length of the cell X(i,2:N+1)=cumsum(dX); %x(2:N+1)-(dx-dX); %Update the Eulerian co-ordinates. L(i)=X(i,N+1); %The length of the rod is the last entry y_old=y; %Set the new solution as the old one. end plot(t,L) r_half=1./nu(end,:); X_half=0.5*(X(end,1:N)+X(end,2:N+1)); r=interp1(X_half,r_half,X(end,:)); v=interp1(X_half,u(end,:),X(end,:)); figure; plot(X(end,:),r); xlabel('X(t)') ylabel('Density'); figure; plot(X(end,:),v); xlabel('X(t)') ylabel('Velocity'); % function y=mass_flux(nu,u) % global N % global dh % y=zeros(1,N+1); % y(2:N)=0.5*(u(2:N)+u(1,N-1)); % y(N+1)=u(N)-0.25*dh(N)*(3*nu(N)-nu(N-1)); % end function y=flux(u,nu,S) %This computes the fluxes required for the finite volume method N=S.N; dh=S.dh; nu_0=S.nu_m; k=0.01; a=0.01; nu_end=1.5*nu(N)-0.5*nu(N-1); nu_0_end=1.5*nu_0(N)-0.5*nu_0(N-1); y=zeros(2,N+1); %This vector will store the fluxes for the mass and momentum y(1,2:N)=0.5*(u(2:N)+u(1,N-1)); %Fluxes for the mass y(1,N+1)=u(N)-(nu_end*k/zeta(nu_end,nu_0_end,S))*dh(N)/2; nu_face=0.5*(nu(1:N-1)+nu(2:N)); %This is specific volume on the cell interface y(2,2:N)=P_L(a,nu_face,nu_0(2:N))+(4*zeta(nu_face,nu_0(2:N),S)./nu_face).*((u(2:N)-u(1:N-1))./(dh(2:N)+dh(1:N-1))); %The flux for the momentum equation %nu_L=1.5*nu(1)-0.5*nu(1); %the specific volume at the end nu_L=nu(1)+dh(1)*(nu(2)-nu(1))/(dh(1)+dh(2)); %The matal powder specific density %nu_0_L=1.5*nu_0(1)-0.5*nu_0(1); nu_0_L=nu_0(1)+dh(1)*(nu_0(2)-nu_0(1))/(dh(1)+dh(2)); y(2,1)=P_L(a,nu_L,nu_0_L)+(zeta(nu_L,nu_0_L,S)/nu_L)*(2*(u(2)-u(1))/(dh(1)+dh(2))); %the fluxes at the end y(2,N+1)=0; end function y=P_L(a,nu,nu_0) %This is the laplace pressure x=1-nu_0./nu; %This is the porosity for an imcompressible metal powder y=a*(1-x).^2; end function y=zeta(z,nu_0,S) eta_0=S.eta; x=1-nu_0./z; y = 2*(1-x).^3*eta_0./(3*x); end function [J] = jacobian(y_old,y,theta,S) % Computes the Jacobian matrix of the function f(x) % f: function handle that returns a vector of function values % x: column vector of independent variables % Number of function values and independent variables n = length(y); % number of independent variables % Initialize Jacobian matrix eps=1e-5; % could be made better J = zeros(n,n); T=zeros(1,n); for i=1:n T(i)=1; fPlus = sintering_RHS(y_old,y+eps*T,theta,S); fMinus = sintering_RHS(y_old,y-eps*T,theta,S); J(:,i) = (fPlus-fMinus)/(2*eps); T(i)=0; end end function f=sintering_RHS(y_0,y,theta,S) %the vector f has the stencil for each cell for both the mass and momentum nu_m=S.nu_m; dt=S.dt; N=floor(length(y)/2); f=zeros(1,2*N); flux_1=flux(y(N+1:2*N),y(1:N),S); %This is flux at timestep i flux_0=flux(y_0(N+1:2*N),y_0(1:N),S); %this is the flux at timestep i-1 f_mass=flux_1(1,:); f_mom=flux_1(2,:); f_mass_0=flux_0(1,:); f_mom_0=flux_0(2,:); f(1:N)=y(1:N)-y_0(1:N)-dt*theta*(f_mass(2:N+1)-f_mass(1:N))-(1-theta)*dt*(f_mass_0(2:N+1)-f_mass(1:N)); %These are the stencils coming from the system of equations f(N+1:2*N)=y(N+1:2*N)-y_0(N+1:2*N)-dt*theta*(f_mom(2:N+1)-f_mom(1:N)-S.alpha*y(1:N))-(1-theta)*dt*(f_mom_0(2:N+1)-f_mom_0(1:N)+S.alpha*y_0(1:N)); f(1)=y(1)-y(2); end function [y] = Newton(tol,y_old,y0,theta,S) iter = 0; maxiter = 10; error=10; J0 = jacobian(y_old,y0,theta,S); %Computes Jacobian J_inv=inv(J0); %[L,U] = lu(J0); while (error > tol) && (iter < maxiter) %J0 = jacobian(y_old,y0,theta); %Computes Jacobian f_old=sintering_RHS(y_old,y0,theta,S); %Computes the old f delta_y = -J_inv*f_old'; %Computes the differencebetween old and new guesses y = y0 + delta_y'; %the new guess error=norm(sintering_RHS(y0,y,theta,S)); %computes the error, the error should be very small y0 = y; iter = iter + 1; %Updates the iteration % fprintf('Iteration %i, norm = %.2f\n', iter, error) end end |
cfd |
Conflicting length scale definition | jonasa97 | CFX | 12 | February 4, 2023 14:38 |
Odd behaviour in circuitBoardCooling | sturgeon | OpenFOAM Running, Solving & CFD | 3 | April 26, 2018 08:22 |
Odd residual behaviour for Two Layer K Epsilon | dvcauwe | Main CFD Forum | 1 | March 7, 2012 05:47 |
extrudeMesh - odd behaviour | grjmell | OpenFOAM | 0 | September 20, 2011 08:41 |
Odd behaviour in wigleyHull in OF 2.0 | msbealo | OpenFOAM Running, Solving & CFD | 0 | July 16, 2011 05:53 |
