Non-CFD heat transfer question
Old   November 17, 2000, 15:56
Default Non-CFD heat transfer question
Adrin Gharakhani
This is (probably) a question for people with hands-on insulation expertise.
There is a concrete cubic box (1x1x1 m^3) with some electronic appliances inside it, which is operating in the desert (no vents, air conditioning, etc.!!) Apparently, the heat generation is not strong enough to cause damage to the electronic equipment.
If we were to replace the concrete with sheet metal (it's less messy and lighter), what type of insulation would you recommend we'd have to use. Are there any paint-type insulation material that will be effective enough. (The problem appears to be one of conduction and radiation heat transfer, but not a research subject. Only a quick but effective solution is required)
Thanks in advance for any thoughts, comments
Adrin Gharakhani
Old   November 18, 2000, 00:14
Default Re: Non-CFD heat transfer question
John C. Chien
(1). Go to a Home Depot store, talk to the building insulation people about the fiber glass insulating material. (2). It comes with various R-rating and thickness for wall and roof insulation.
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Simple 2d Heat transfer question Richard FLUENT 2 January 18, 2006 22:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
conjugate heat transfer question Kirill CFX 0 January 10, 2003 04:50
