January 8, 2001, 15:53 |
Block sparse matricies
I have written an explicit unstructured solver operating on general polyhedral meshes. I am in the process of making it implicit and need a way to solve the resulting block sparse matrix system. I have in the past successfully used the code from Saad (GMRES; available from his website) to solve scalar sparse matricies does anyone know how to store block sparse matricies to be solved by this same GMRES solver or does anyone know where I can get my hand on such a beast (hopefully with some documentation).
Thanks |
January 10, 2001, 11:05 |
Re: Block sparse matricies
Could you please give the address to Saad's website, where he has the downloadable GMRES code? Thanks a lot.
Jin |
January 10, 2001, 13:13 |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 7 | November 15, 2021 22:56 |
[ICEM] Quest for seemingly simple Blocking (degenerate block) | la7low | ANSYS Meshing & Geometry | 0 | July 12, 2011 19:48 |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 0 | September 15, 2010 08:34 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
blockMesh: block with 6 vertexes | dani | OpenFOAM | 3 | June 25, 2009 13:13 |
