August 23, 2001, 11:31 |
Pipe Flow
A really stupid question. What would be the boundary conditions for a pipe flow except for specifying the inlet flow.
August 24, 2001, 02:50 |
Re: Pipe Flow
pressure ?
August 27, 2001, 10:47 |
Re: Pipe Flow
at wall you have to apply no slip conditions. at exit gradient of the properties are zero provided your pipe length is sufficient. i mean fluid is fully developed. are want to treat the flow as axisymmetric?.
are you treating the flow as a laminar or turbulent. which turbulence model u want to use?. then you to consider some more stuff. by rajani |
LES transitional pipe entrance flow | hasanduz | Main CFD Forum | 2 | October 11, 2013 17:59 |
HTC in Pipe flow | subsemitonium | CFX | 6 | May 6, 2013 22:00 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
