Any numerical triple integration program is available in Fortran?
Old   January 14, 1999, 01:11
Default Any numerical triple integration program is available in Fortran?
Radhakrishnan
I have a complicated equation in terms of Sine and Cosine which contains a vector integration. However, the Mathematica software failed to perform the analytical integration. Is there any software other than Mathematica which is capable to perform a complicated analytical integeration? The program quad3d in 'Numerical recipes in Fortran' is not practical in this case. Because, this program takes at least 2 hours to perform one integration from -inf to +inf with our equation and we have to do at least 1 Lakh iterations during our computations. Is there any numerical program available to do a triple integration within a reasonable time in Fortran language? Let me know your suggestions and insights in this regard.
With regards,
Radhakrishnan. K
Old   January 14, 1999, 17:19
Default Re: Any numerical triple integration program is available in Fortran?
Adrin Gharakhani
It's not clear from your description what you are integrating, more specifically, how many variable parameters are involved in your integral. In general, if the integrals are expensive (e.g. elliptic integrals) it's a good idea to create tables for them, which will cost you time just once; in the computations all you have to do is to look the tables up (plus simple interpolation, which are fast). If you have many parameters, then you can at least reduce their number by doing a hybrid table/analytic, table/numerical, etc.
Hope I haven't stated the obvious
Adrin Gharakhani
Old   February 15, 1999, 12:37
C.S.Venkatasubban
Hello:
Based on the very limited information you have provided about your problem, I can offer the following suggestions.
1. Since your function is composed of sines and cosines,
I would strongly urge you to attempt a solution through
the use of Fourier techniques. ( an FFT may be applicable
to your problem, and could give you an answer that is
thousands of times faster than a "brute force" approach).
2. SInce you seem to be integrating between (+/-) inf,
you need to introduce a change of variables so as to
integrate between finite limits. This is easily done.
3. If your boundary is of a complex shape, then your best
bet is to employ Gaussian integration techniques along
each direction. It is possible to decompose your volume
integral into surface integrals on the boundary. The
surface integrals in turn may be decomposed into line
integrals along each elementary surface defining your
volume. These line integrals are finally evaluated by
Gaussian integration. I would be happy to provide more
details of this method.
Old   March 4, 1999, 01:03
Radhakrishnan. K
Hello Sir,
Many many thanks for your helpful response on my question. Meanwhile, I have solved my problem using some numerical methods.
Call Fortran program from OpenFoam tsjb00 OpenFOAM Running, Solving & CFD 6 April 22, 2013 15:26
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Fortran Program with FLUENT UDFs gautamcfd FLUENT 0 August 17, 2010 05:39
Numerical integration Damir Galeev Main CFD Forum 2 June 24, 2001 05:59
control plotting in fortran program zhe zhang Main CFD Forum 2 November 16, 1999 13:10
