Import to CAD - Gambit
Old   November 18, 2002, 11:37
Default Import to CAD - Gambit
guest
hi, I have data for a geometry in x,y,z format in excel files. how do i import this into Gambit or autocad? i want to read the data as solid geometry into Fluent at later stages.
Old   November 19, 2002, 06:05
Default Re: Import to CAD - Gambit
Helper.
Check the syntax of the input file for Gambit. I am sure you should be able to manipulate a text file output from excel such that it can be opened in Gambit or CAD. i would imagine iges would be a likely format.
Old   November 19, 2002, 06:10
An Modh Coinniolach
You can import vertex data into Gambit. Save your xyz data in a *.dat file and import to Gambit using >import >vertex data
Old   November 20, 2002, 06:23
guest
hi, i have tried importing as vertex data. but, i am getting errors. "error reading no. of points per curve and no. of curves"
Old   November 20, 2002, 07:53
Helper
Try importing a much smaller mesh first, say simply the points on the surface of a square of something. Then see where your error might be coming from.
Old   November 21, 2002, 10:37
ravi varma
i am having the same problem too. if one looks at the data file exported from gambit the syntax is different. it may be impossible to import from excel by manually typing a syntax to match so that gambit can read it. is there any VB code that can be used to import vertex data from excel into gambit?
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
GAMBIT, CAD import, clean up geometry problem Nuray Kayakol FLUENT 1 December 30, 2007 11:43
I-DEAS CAD data import with boundary conditions Yunus FLUENT 2 March 14, 2001 14:45
How to Import 3D objects from Pro-Engineer to Gambit? Tomb FLUENT 3 July 5, 2000 12:12
Autocad import into Gambit Paul Main CFD Forum 5 July 12, 1999 04:19
