John Stewart
Rep Power: 15 ![]() |
I am having trouble validating a mesh for an airfoil created in gambit. Fluid is air I am having trouble getting the wall shear stress.Is it correct that i complete analysis in fluent and then use the value i get from fluent, in wall fluxes, as tau(wall shear stress) The height of the first cell is 0.00038. not sure of the units Any help would be very much appreciated because I am at a stand still with my project at the moment Thanks, John ![]() ![]() ![]() ![]() ![]() Last edited by johnstewart00; April 2, 2009 at 13:54. |
N/A
Yes. You run your code for sometime and depending on if the simulation is RANS/LES wait for steady state or IC effects to vanish and then check the value of yplus. For an airfoil, if you look in the literature, you might find many references on the value of y used to get yplus < 1 for any Re.
Janarthanan Alagesan
Hi John,
Your requirement is only tau or something else. Can you give further details. Usually the first cell height will be in m or mm, i.e. depends on the unit selected in gambit. From the following link you can find the first cell height http://geolab.larc.nasa.gov/APPS/YPlus/ Cheers, Alagesan |
Display Modes | |
Mesh geometry over airfoil with Gambit | laith | FLUENT | 5 | March 9, 2018 01:56 |
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 06:11 |
Help needed with Cornell's Gambit airfoil tutorial | AW | FLUENT | 6 | February 26, 2010 22:42 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
Heated Boundary Layer Airfoil | John Patrick | FLUENT | 0 | January 18, 2002 12:02 |
