How to find a good initial guess for a BVP
Old   January 25, 2010, 16:32
Smile How to find a good initial guess for a BVP
Yan Yan
yyvyan2000 is on a distinguished road
Hi All,
Can anyone please share some hints on how to find a good inital guess?
I am solving a nonlinear BVP(steady-states) extracted from a time-dependent problem by setting d/dt=0. The equation is conservational law for mass, momentum, internal energy, with an algebraic heating source. v(velocity), P(pressure), U(fluid internal energy), can be solved from this coupled system.
I am using Newton's method for this nonlinear system. Frankly, I do not have a good initial guess for the solver. The only information that I have is the inital condition for the time-dependent problem, where the BVP comes from. I have runned my solver with different inital guess many times, but with no luck of a satisfying residual reduction.
So, do I have to solve the time-dependent problem after a long time stepping to get a steady solution? Or is there any better way of finding a good initial guess?
Any suggestion is highly appreciated.
Yan
yyvyan2000 is offline   Reply With Quote
Old   January 25, 2010, 21:51
Default Implicit time-stepping to Newton
gory is on a distinguished road
I think I've read this issue in a CFD book (Fletcher's book?).
You may want to add a time term to the Jacobian (just like an implicit time-stepping), and guadually take the time step to infinity (so that the time term goes to zero and finally the method reduces to the Newton iteration). Small time step enlarges the radius of convergence.
Good luck.
gory
gory is offline   Reply With Quote
Old   January 26, 2010, 11:31
Yan Yan
Thanks for the reply.
I think I will try continuation method as suggested by an expert. I have not read anything about that. But I will start soon
Yan
Old   January 27, 2010, 13:05
Yan Yan
Hi Gory,
Just to confirm that I did find a chapter on steady-state problem in Fletcher's book. Also what you said is exactly continuation method.
Again, thanks a lot for providing the reference.
Yan
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Error log vw.cfd OpenFOAM 6 August 7, 2009 05:44
reactingFoam: adiabatic flame temperature rFkhemek OpenFOAM 2 July 31, 2009 06:42
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
