how to set the periodic BC in channel?
Old   April 2, 2004, 10:06
Default how to set the periodic BC in channel?
Bin Li
the channel flow is computed with 3d compressible NS code using MacMarco scheme. in stream wise the periodic bc is used, denoted f_x. in aiaa paper 98-3315, it was -2.*u_taw**2. another paper suggest that it is evaluated using f(d_u/dy). which is better? my code is not valid for this problem now. in initial conditions, all flow parameters is uniform. u=1,v=w=0, density r=1, temperature T=1.(non-dimension) and i add a fluctuate to u within [-0.05,0.05] at inlet boundary in certain time-step. the flow can not develop. i think maybe the initial u is wrong. anyone can send me a velocity profile datas with any Mach number any Renoly number, only compressible. thanks. maybe you would give some advice about it. best regards
Periodic boundary in unsteady flow ac2011 FLUENT 0 September 26, 2011 06:52
How did I set a discharge or depth curve at inflow boundary? (open channel problem) Andy Chen FLUENT 0 June 29, 2009 10:11
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 5 May 12, 2006 18:42
OpenFOAM installation on SUSE92 problems derath OpenFOAM Installation 1 April 3, 2006 06:44
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
