April 7, 2010, 11:19 |
area weighted average
anif hidayatullah
Rep Power: 16 |
I am a student from Indonesia. Now, I conduct research on water liquid flow in porous media using fluent. I have a problem with my case. I use velocity inlet and pressure outlet the boundary condition.
velocity inlet = 8.5 m/s pressure outlet = 0 pascal after i simulate the case and confergence, then i see area weighted average for outlet. I was surprised, when I saw the pressure at the outlet -15 pascal. please help me? why? thank's before |
April 7, 2010, 12:11 |
Rep Power: 18 |
I don't use Fluent, but it sounds like you should interpret that as 15 pascals below the inlet pressure - that is, that's the pressure loss the system incurs in driving the flow. Most pressure-based solvers work with a relative, or gage, pressure instead of an absolute pressure. So negative pressures are not uncommon. Figure out what your pressure is relative to, and then get concerned if the absolute pressure in your flowfield is negative.
April 7, 2010, 13:47 |
anif hidayatullah
Rep Power: 16 |
thank's agd
I'll check again, if the outlet pressure value relative to other pressures. |
area weighted average |
Area weighted or mass weighted average | SAM | Main CFD Forum | 31 | April 30, 2018 04:12 |
Diffference between mass weighted average and Area | giogio | FLUENT | 9 | March 6, 2018 08:24 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Area weighted average | ashish | FLUENT | 1 | April 12, 2005 18:02 |
area weighted average | Sireesha Pasari | FLUENT | 1 | April 4, 2004 13:06 |
