July 22, 2004, 08:35 |
Backward Facing Step
Hi All, I am looking for some dataset (experimental/DNS/LES) of a supersonic backward facing step flow (planar, not axi geometry, pls) . Is anybody aware of such a dataset? THanks Jimmy
July 25, 2004, 15:32 |
Re: Backward Facing Step
Hi, You may look at the paper "Predictions of axial and transverse injection into supersonic flow" Palaniswamy et al. Flow,Turbulence and combustion 66, pp 37-55. 2001 -amol
July 25, 2004, 18:02 |
Do you have the paper? I dont have good access to different journals, will it be possible to get either electronic or paper copies of the article? Thanks jimmy
July 25, 2004, 22:37 |
Look at:
ftp://torroja.dmt.upm.es/ "AGARD Test Cases for the Validation of Large-Eddy Simulations of Turbulent FLows A wide range of test cases focused on LES simulations. Includes a lot of data, including correlations etc. You can download and print all documentation yourself. The database was compiled by AGARD in 1997. Highly recommended! " From this very website. |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Backward facing step. | Fluids | Main CFD Forum | 7 | December 4, 2012 11:28 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
