maintain a constant flow rate in channel flow ?
Old   January 8, 2004, 23:58
Default maintain a constant flow rate in channel flow ?
Lewis
How to maintain a constant flow rate in the DNS of turbulent channel flow? I have taken a long time to look up the appropriate methods from papers, and found that there is two ways, one is to adjust the velocity field, the other one is to adjust the mean pressure gradient. However, the papers have not mentioned how to do it in detail. If you have the experience on this, please tell me the detailed method. Thanks very much.
Old   January 9, 2004, 03:23
Default Re: maintain a constant flow rate in channel flow
Tom
In both methods you impose a linear pressure gradient (you don't adjust the velocity). This linear pressure gradient can be just a constant (You just add a constant to the momentum equation of the streamwise velocity component.In this case the bulk velocity will fluctuate a little bit around a mean value, but on average the pressure force should be balanced by the wall shear stress.), or you give the pressure gradient a certain value so that the bulk velocity is equal to some constant value (This means that the pressure gradient will fluctuate a bit). The first method is very simple to implement. With the second method you get a bit faster converged turbulent statistics.
Tom
Old   September 28, 2010, 11:35
Default references
rgm
rgm is on a distinguished road
Could somebody give references for a comparison between imposing constant flow rate or pressure gradient, please?
Thanks!
rgm is offline   Reply With Quote
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Constant Volumetric Flow Rate Boundary Condition Hadley Main CFD Forum 0 October 20, 2005 23:13
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
Constant mass flow rate / choking outlet bounardy condition Min Zhu Main CFD Forum 1 September 29, 1998 15:33
