FOAM
Old   September 20, 2004, 13:12
Default FOAM
CFDtoy
Hello All,
Has anyone used FOAM Software for simulating unsteady flows?
Thanks
CFDtoy
Old   September 20, 2004, 21:57
Default Re: FOAM
luiz
Yes. I have. LESimulation.
Old   September 21, 2004, 07:41
Default Re: FOAM
baal
is it a free software? how can i get it?
thanks.
Old   September 21, 2004, 09:40
Default Re: FOAM
matej
you can have a free license for academic use; surf to www.nabla.co.uk, or you can search this forum, I gues the link is here about 10 times already. You may also find google or other search engine to be usefull.
matej
Old   September 21, 2004, 10:44
Default Re: FOAM
CFDtoy
Hi Luiz,
I would like to know if you were able to access the source code as claimed by FOAM. Were you able to implement any of your own algorithms or additional subroutines ?
CFDtoy
Old   September 21, 2004, 14:09
Default Re: FOAM
luiz
Yes. The source code is really available, and yes, I have done some interesting things myself. I think the main advantage of FOAM is its OO philosophy, which makes it very easy to implement new algoritms. Since there are many differential operators readily available (both spatial and temporal), you can mount new equations/variables/models adding a couple of lines to the original code, without having to worry about the lower layers... For instance, if you want to solve a completely new equation for a tensor T, you could just add:
fvMatrix T { fvm::ddt(T) - fvm::div(T) == fvc::curl(U) } T.solve()
This little piece of code is almost self explanatory: 1) build a matrix T to be solved; 2) obeying the equation ddt(T) -div(T) = curl(U) (That is just an example meaning nothing, just to show you are not tied to navier stokes eq); here fvm is a class of implicit operators, while fvc is for explicit ones...; 3) then solve the eq.
This way, you can QUICKLY implement new models, or even new algorithms, focusing only on what you need. And I think that is why they are able to offer so many turbulence models, multiphase, etc ready to use with their package. I also expect them to be quicker to release new algorithms, models, etc than other commercial codes.
As you can see, I am enjoying a lot the code, and I am becoming a big fan of C++ and FOAM...
good luck
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
