Viscous spacing
Old   December 22, 2004, 15:06
Default Viscous spacing
CFD Student(EK)
Viscous spacing next to the wall for laminer flows? Thanks...
Old   December 22, 2004, 15:22
Default Re: Viscous spacing
Biga
Try approximating by a laminar flat plate flow, to which the theoretical solution is available (Blasius profile).
You should have the Reynolds number for your simulation, and you should have about 10 to 40 points inside the boundary layer (eta = 6 from Blasius solution), depending on your convective flux computation scheme. If it's 2nd-order upwind, go with about 15. If it's centred with artificial dissipation, go with about 40.
By the Blasius' eta definition with your Reynolds number, to give you the laminar boundary layer thickness over the flat plate, and the number of points inside the boundary layer, you get the point distribution along your BL.
Viscous resistance coefficients in porous medium fpingqian FLUENT 50 June 26, 2019 01:55
adapt viscous resistance based on velocity / UDF Häwimeddel FLUENT 2 April 20, 2009 10:08
viscous spacing next to the wall CFD student Main CFD Forum 2 November 22, 2004 17:19
VISCOUS heat dissipation Joseph CFX 0 October 1, 2004 08:52
Viscous Grid Spacing Calculator firedragon FLUENT 4 February 10, 2004 04:38
