modelling pump-sump using VOF
Old   December 23, 2013, 06:26
Default modelling pump-sump using VOF
Virendrasingh Pawar
virendra_p is on a distinguished road
hello,
i am using vof method to model standard pump model ( v c patel et al. 1998). water flows from inlet into the sump and then through suction pipe. i have defined a fixed volume of air over water domain. for turbulence i am using ke-std with scalable wall functions. after convergence i found that streamlines form the water surface are entering into air domain!! (note: single phase results for same problem were fairly accurate)
please help me with suggestions and comments.
virendra_p is offline   Reply With Quote
Interfoam - sump pump modelling cfdan OpenFOAM Running, Solving & CFD 17 October 12, 2021 12:04
Low temperatures modelling heat pump with source terms stahl FLUENT 0 November 26, 2010 16:43
pump meshing inside the sump ashwin FLUENT 0 March 16, 2007 06:57
Pump in a sump meshing Ashwin C Punjabi FLUENT 0 March 12, 2007 23:52
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 16:22
