[ICEM CFD] Problem meshing two indipendent but contacting bodies
Old   December 12, 2016, 09:31
Default [ICEM CFD] Problem meshing two indipendent but contacting bodies
Giorgio
Faggio11 is on a distinguished road
Dear all,
in my geometry I have to separate and independent bodies which represent the leaflets of a mechanical valve in the heart. They are supposed to rotate with respect to an axis and I am going to simulate their motion through a UDF function in Fluent.
The starting configuration is in closed configuration (see picture attached - I only show the region of interest but they are contained in a circular geometry). When I move to the meshing process, the two bodies happen to be in contact in this position. When I rebuild the geometry I have used different tolerances but the software always considers the two contacting surfaces as one. The problem is that when I apply the meshing algorithm to get tetras, the topology of the mesh is not distinguished between the two bodies. Thus, when I apply my motion, the two leaflets seem to remain constrained the one with the other, connected by some elements.
Is there a way I can get rid of this problem?
Thank you in advance,
Fg.
EDIT: I have created a small gap between the two surfaces. The gap is of the order of about 0.01 mm. When I do meshing then I always get the same problem, so the two surfaces are meshed together - even if this time they are directly in contact. Is it because I have not chosen proper mesh size for curves?
Last edited by Faggio11; December 13, 2016 at 12:07. Reason: modification of the conditions which lead to the problem
Faggio11 is offline   Reply With Quote
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
[ICEM] Tetra meshing problem Smaras ANSYS Meshing & Geometry 4 February 21, 2013 09:04
Problem exporting line bodies form Design Modeler to Mesh Editor&Fluent Rockda ANSYS Meshing & Geometry 0 May 26, 2011 11:03
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
