Spherical packing loading error in Salome (non valid shape) |
Adriaan De Bolle
Rep Power: 0 ![]() |
Dear all nice (helpful) people,
I have some external file to calculate centres of mono-sized spherical packings. Attached is a text file a random packing (shakenAndCompressed). File test.py is the python script to load into Salome. Loading error: Traceback (most recent call last): File "<input>", line 1, in <module> File "/home/adriaan/packedBedRandom.py", line 79, in <module> fluid = geompy.MakeCut(fluid, sphere) File "/home/adriaan/salome/appli_V7_6_0/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 7660, in MakeCut return self.MakeBoolean(theShape1, theShape2, 2, checkSelfInte, theName) File "/home/adriaan/salome/appli_V7_6_0/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 284, in OpenCallClose res = theFunction(self, *args, **kwargs) File "/home/adriaan/salome/appli_V7_6_0/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 7554, in MakeBoolean RaiseIfFailed("MakeBoolean", self.BoolOp) File "/home/adriaan/salome/appli_V7_6_0/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 299, in RaiseIfFailed raise RuntimeError, Method_name + " : " + Operation.GetErrorCode() RuntimeError: MakeBoolean : Boolean operation aborted : non valid shape result I tried MakeCut within the loop, MakeCutList after the loop, PartitionTool. I also tried a normal cylinder instead of divided disk. For the regular packing I tried with and without gap. I tried increasing/decreasing Tolerance and using ProcessShape Tool, but errors weren't gone. How can I exclude/avoid this problem? Thanks a lot! Kind regards. |
Display Modes | |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[Salome] Spherical slice in Salome for OpenFOAM | Jakob1 | OpenFOAM Meshing & Mesh Conversion | 1 | January 10, 2014 03:51 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
How to calculate shape factor of spherical cap bub | Rajeev Kumar Singh | FLUENT | 0 | October 6, 2005 13:07 |
