Home > Forums > Special Topics > Mesh Generation & Pre-Processing
problem in skewness
Like Tree1Likes
  • 1 Post By oozcan
Old   March 23, 2016, 03:42
Default problem in skewness
yaseen
yaseen wsu is on a distinguished road
hello every one
I have a problem in meshing my geometry, because skewness reaches 0.99, critical location for this is boundary between two parts of geometry which is (tetra and hexa) mesh, I can create hexa mesh for upper part by all methods (mulizone, swipp..) how can I improve skewness, also I used function size but only reach 0.97. thanks
http://www.cfd-online.com/Forums/att...1&d=1458722464
http://www.cfd-online.com/Forums/att...1&d=1458722476
http://www.cfd-online.com/Forums/att...1&d=1458722490
yaseen wsu is offline   Reply With Quote
Old   May 13, 2016, 13:57
Onur Özcan
oozcan is on a distinguished road
could you please give more concrete .jpeg? and Can I see your mesh-tree more detail?
if you share all of this? I would be helping you out .
Kind Regards,
yaseen wsu likes this.
oozcan is offline   Reply With Quote
Old   May 14, 2016, 06:42
yaseen
thanks for your reply
I tried to reduce skewness by sizing function to 0.938 but till now very high see attached photo
http://www.cfd-online.com/Forums/att...1&d=1463222335
http://www.cfd-online.com/Forums/att...1&d=1463222342
http://www.cfd-online.com/Forums/att...1&d=1463222368
http://www.cfd-online.com/Forums/att...1&d=1463222384
http://www.cfd-online.com/Forums/att...1&d=1463222400
Old   May 14, 2016, 10:37
Onur Özcan
I couldnt see all attachment photos. I do not know but,
Actually that skewness you have attained is a quite bit enough to solve your model.
I could not comment your meshing as couldnt see your photos,if any meshing has mapped face, might as well remove it, I prefer and use it when model has two or multiple part of bodies are contacted eachother,that is, if gap or overlapping occur in two parts then you should use mapped face meshing in contacted surface or faces
Tetra meshing is most prefered choice in most cases of problems.Relevance factor is revelant to your model sensitivity and it causes time-consuming and not-economical in solving all models.
Better relevance or accuracy of solving your problem would be made tetra meshing but for hexa.Hexa leads to minimal nodes or cells and then, relevance factor would be incereased by your choice (if skewness,orthogonal,aspect ratio are enough value )
Kind Regards,
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
