Home > Forums > Special Topics > Mesh Generation & Pre-Processing
how can i generate the best mesh for this geometry ???
Old   July 28, 2017, 14:15
Question how can i generate the best mesh for this geometry ???
Nima
n7ma is on a distinguished road
Hey everyone
i have a box that a pipe passes through it.
both side of the pipes are Inlets.
and theres a hole (1mm Diameter ) on the pipe that air flowes to the box.
solution should continue until the box filles and pressure of pipe and box be equal.
please help me with mesh gerenating , im beginner , every help can be usefull for me , thanks a lot
the Geometry File
https://ufile.io/tqvzg
image of Geometry :
https://img2.brain4.photobox.com/166...ab94601bd0.jpg
n7ma is offline   Reply With Quote
Old   August 2, 2017, 12:57
ali.ikhsanul's Avatar
Ali Ikhsanul Qauli
ali.ikhsanul is on a distinguished road
Send a message via Skype™ to ali.ikhsanul
Do you have step or stp file of the geometry?
I can help meshing the geometry by using snappyHexMesh, but first I need step file instead to import in SALOME.
ali.ikhsanul is offline   Reply With Quote
[ANSYS Meshing] Assembly mesh "misses" gaps in geometry vjbhatt ANSYS Meshing & Geometry 2 September 25, 2014 02:52
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] How to generate unstructure mesh of this geometry? llrr ANSYS Meshing & Geometry 6 May 28, 2013 03:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
