Merge meshes from two cylinders with different diameters |
February 1, 2023, 09:48 |
AdrienP
I would like to study the flow of gas in a cylindrical capillary followed by a larger cylindrical volume. I am using salome-platform to create the geometry and the mesh. I would like to know what is the best strategy to have such mesh.
My initial idea was to create a mesh for both cylinders and then to merge the meshes. I would simply generate two cylidners, select some mesh properties for the volumes and surfaces (inlet and outlet). Then I could export in .unv to OpenFOAM. This idea comes from the fact I already tested an hexahedral mesh for the first capillary geometry and I would like to complete this geometry. The capillary is built as a divided cylinder that I mesh with 3D extrustion, quadrangle mapping for 2D and wire discretisation for 1D (see image 1). The inlet and outlet also have 2D and 1D parameters set to have a satisfying CFD simulation. As a matter of fact, I already tried this, found something looking satisfying, with a fine mesh around the capillary (see image 2). Both meshes connect well and so, but my problem is that doing so I have 1000 pyramids, and unv format do not support pyramids. So maybe there is an alternative, I could do things differently. Last edited by Aldehyde; February 1, 2023 at 09:49. Reason: Images too small |
mesh, openfoam, salome meca |
[ICEM] merge meshes between hexa and prism | jjz2013 | ANSYS Meshing & Geometry | 39 | February 12, 2019 10:38 |
Merge and Stitch meshes using pyFoam libraries | shaileshbg | OpenFOAM Programming & Development | 1 | February 19, 2018 01:30 |
Merge Meshes in parallel | DominicTNC | OpenFOAM | 0 | September 4, 2017 22:39 |
[ICEM] Smoothing before merge meshes | FJSJ | ANSYS Meshing & Geometry | 0 | May 20, 2013 11:30 |
[ICEM] merge two hexa meshes | gajemon | ANSYS Meshing & Geometry | 1 | January 29, 2011 19:49 |
