Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Merge meshes from two cylinders with different diameters
Old   February 1, 2023, 09:48
Default Merge meshes from two cylinders with different diameters
AdrienP
Aldehyde is on a distinguished road
I would like to study the flow of gas in a cylindrical capillary followed by a larger cylindrical volume. I am using salome-platform to create the geometry and the mesh. I would like to know what is the best strategy to have such mesh.
My initial idea was to create a mesh for both cylinders and then to merge the meshes. I would simply generate two cylidners, select some mesh properties for the volumes and surfaces (inlet and outlet). Then I could export in .unv to OpenFOAM.
This idea comes from the fact I already tested an hexahedral mesh for the first capillary geometry and I would like to complete this geometry. The capillary is built as a divided cylinder that I mesh with 3D extrustion, quadrangle mapping for 2D and wire discretisation for 1D (see image 1). The inlet and outlet also have 2D and 1D parameters set to have a satisfying CFD simulation.
As a matter of fact, I already tried this, found something looking satisfying, with a fine mesh around the capillary (see image 2). Both meshes connect well and so, but my problem is that doing so I have 1000 pyramids, and unv format do not support pyramids. So maybe there is an alternative, I could do things differently.
Aldehyde is offline   Reply With Quote
mesh, openfoam, salome meca
[ICEM] merge meshes between hexa and prism jjz2013 ANSYS Meshing & Geometry 39 February 12, 2019 10:38
Merge and Stitch meshes using pyFoam libraries shaileshbg OpenFOAM Programming & Development 1 February 19, 2018 01:30
Merge Meshes in parallel DominicTNC OpenFOAM 0 September 4, 2017 22:39
[ICEM] Smoothing before merge meshes FJSJ ANSYS Meshing & Geometry 0 May 20, 2013 11:30
[ICEM] merge two hexa meshes gajemon ANSYS Meshing & Geometry 1 January 29, 2011 19:49
