Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
problem in eigenValues
Like Tree1Likes
  • 1 Post By huangxianbei
Old   November 1, 2014, 04:26
Default problem in eigenValues
Huang Xianbei
huangxianbei is on a distinguished road
I checked the way calculating eigenValues in OF 2.1.1and found a problem.
In OF,
scalar a = -t.xx() - t.yy() - t.zz();
00106
00107         scalar b = t.xx()*t.yy() + t.xx()*t.zz() + t.yy()*t.zz()
00108             - t.xy()*t.yx() - t.xz()*t.zx() - t.yz()*t.zy();
00109
00110         scalar c = - t.xx()*t.yy()*t.zz() - t.xy()*t.yz()*t.zx()
00111             - t.xz()*t.yx()*t.zy() + t.xz()*t.yy()*t.zx()
00112             + t.xy()*t.yx()*t.zz() + t.xx()*t.yz()*t.zy();
So a=-I_1=tr(T),b=I_2, c=-I_3
The eigenValues can be calculated as following:
Last edited by wyldckat; January 31, 2015 at 10:19. Reason: repaired code that was incorrectly copy-pasted into the [CODE] markers
huangxianbei is offline   Reply With Quote
Old   November 1, 2014, 04:33
Huang Xianbei
let check it:
scalar Q = (a*a - 3*b)/9; 00137 scalar R = (2*a*a*a - 9*a*b + 27*c)/54;
scalar sqrtQ = sqrt(Q); 00146 scalar theta = acos(R/(Q*sqrtQ)); 00147 00148 scalar m2SqrtQ = -2*sqrtQ; 00149 scalar aBy3 = a/3;
So R=q/2;Q=-p/3;sqrtQ=sqrt(-p/3);theta=acos(R/(Q*sqrtQ))=acos(-3q*sqrt(-3/p)/(2p))
Then, the problem comes that theta is not equal to acos(3q*sqrt(-3/p)/2p) as in the above formulations in the picture
Is it a bug?
PS: why in OF, -lambda is returned instead of lambda?
Xianbei
Old   November 1, 2014, 07:00
Huang Xianbei
after a further calculation, I found that it's right in OF if we list all the eigenValues.
for simplification, take 3q*sqrt(-3/p)/2p =x, in OF, theta = -x,
so according to OF, lambda (only the cosin term)should be:
1\ cos(1/3*arccos(theta)+2*pi/3)
2\ cos(1/3*arccos(theta))
3\ cos(1/3*arccos(theta)-2*pi/3)
if we use x instead
1\ cos(1/3*arccos(x)+2*pi/3)
2\ cos(1/3*arccos(x)-2*pi/3)
3\ cos(1/3*arccos(theta))
which is the same as in the original form.
So it's not a bug , but a misunderstanding of mine.
But I still want to ask: why is -lambda returned instead of lambda?
Xianbei
Tushar@cfd likes this.
Old   January 31, 2015, 10:26
Retired Super Moderator
Bruno Santos
Hi Xianbei,
Note sure why, but you might want to revisit this topic by checking the source code for OpenFOAM 2.3.x: https://github.com/OpenFOAM/OpenFOAM...ensor/tensor.C
I say this because of this bug report and subsequent fixes: http://www.openfoam.org/mantisbt/view.php?id=1373
Best regards,
Bruno
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
