[solids4Foam] pointD BCs for FSI with fixedDisplacementZeroShear BCs |
November 17, 2019, 08:39 |
Torsten Schenkel
Rep Power: 12 |
I am trying to validate solids4Foam FSI for arterial flows. My validation case is a Moens-Korteweg situation with a pressure jump at t=0, using a short 3d tube geometry as in: Lee, S. H., Choi, H. G. and Yool, J. Y. (2012) ‘Finite element simulation of blood flow in a flexible carotid artery bifurcation’, Journal of Mechanical Science and Technology, vol. 26, no. 5, pp. 1355–1361 [Online]. DOI: 10.1007/s12206-012-0331-9. The case is quite similar to the 3dTube tutorial, but with a full 3d tube instead of the 2 symmetry conditions. I started with the rigidly fixed BCs at inlet and outlet: Code:
D: type fixedDisplacement; value uniform (0 0 0); Code:
pointD: type fixedValue; value uniform (0 0 0); Code:
D: type fixedDisplacementZeroShear; refValue uniform (0 0 0); value uniform (0 0 0); Code:
pointD/pointDD: type fixedValue; value uniform (0 0 0); Code:
calculated Which BC for pointD is compatible with fixedDisplacementZeroShear? Or which combination of BCs can I use to allow for movement in the plane? Another one: Is there a BC that will provide a non-reflective BC on the outlet side for the fluid? But I will put that in a separate thread. Thanks T |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 02:47 |
[swak4Foam] switch between existing BCs with groovyBC?! | michielm | OpenFOAM Community Contributions | 3 | September 4, 2013 08:01 |
Difference between HF and Temperature BCs | Catthan | FLUENT | 0 | August 7, 2013 05:59 |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
Understanding Code behind BCs | Linse | OpenFOAM Programming & Development | 8 | January 9, 2012 08:58 |
