Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[stressAnalysis] How to simulate thermal stress and heat transfer simultaneously using OF?
Old   May 24, 2011, 08:14
Default How to simulate thermal stress and heat transfer simultaneously using OF?
Marco Bernardes
masb is on a distinguished road
Dear All,
I need help to simulate thermal stress and heat transfer simultaneously using OF.
Any help is welcomed.
Many thanks,
Marco.
masb is offline   Reply With Quote
Old   May 24, 2011, 17:20
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Marco,
SolidDisplacementFoam solves for thermal stress and temperature, check out the tutorial.
Philip
bigphil is offline   Reply With Quote
Old   May 25, 2011, 05:21
Marco Bernardes
Hi Philip,
That's great! Thank you for your help.
Regards,
Marco.
Old   May 25, 2011, 05:39
Marco Bernardes
Hi Philip,
The tutorial was set to not solve the thermal equation. Could you help me put the thermal equation working?
Regards,
Marco.
Old   May 25, 2011, 05:48
bigphil's Avatar
Philip Cardiff
Marco,
In the tutorial "constant/thermalProperties" file, change "thermalStress no;" to "thermalStress yes;".
The solver will now solve the energy equation (for temperature) after solving the momentum equation (for displacement).
Hope it helps,
Philip
Old   May 25, 2011, 07:21
Default Foam fatal io error:
Marco Bernardes
Dear Philip,
Then I get the following error message:
Regards,
Marco.
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/marco/OpenFOAM/marco-1.7.1/run/tutorials/stressAnalysis/solidDisplacementFoam/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
Old   May 25, 2011, 08:27
bigphil's Avatar
Philip Cardiff
Marco,
You seem to be running the solidDisplacementFoam solver inside the solver source code directory, you must run the solidDisplacementFoam solver in the tutorial case directory (i.e. inside plateHole).
The user guide shows one how to run this plateHole tutorial (http://www.openfoam.com/docs/user/pl...hp#x6-370002.2), the only difference is that you will have to turn on the thermalStress option in thermalProperties.
Philip
Old   May 25, 2011, 08:56
Default Source code directory
Marco Bernardes
Philip,
Sorry to bother you but I ran it in the source code directory.
I tried both options. Using "thermalProperties no;" it works fine.
Using "thermalProperties yes;" I get the mentioned message.
Regards,
Marco.
Old   May 25, 2011, 09:13
bigphil's Avatar
Philip Cardiff
Marco,
What version of OpenFOAM are you using?
I just tried solidDisplacementFoam and plateHole in OpenFOAM-1.6-ext and it works fine when I turn on "thermalStress" in "constant/thermalProperties".
Just to recap, did you try the following:
copy the tutorial to your home directory -
$ cp -r $FOAM_SOLVERS/stressAnalysis/solidDisplacementFoam/plateHole $FOAM_RUN/
change into the plateHole directory -
$ cd $FOAM_RUN/plateHole
edit "constant/thermalProperties" and turn "thermalStress" to yes.
then run the solver in the plateHole directory -
$ solidDisplacementFoam
If you might get an error about a ddtScheme not being defined, then put this in the "system/fvSchemes" file:
ddtSchemes
default Euler;
Also you will have to increase the number of correctors in the "system/fvSolution" file to something like 1000:
stressAnalysis
compactNormalStress yes;
nCorrectors 1000;
D 1e-06;
Philip
Old   May 25, 2011, 09:53
Default It works fine.
Marco Bernardes
Philip,
Thank you. It works but the temperature output is constant. I think I should change the initial and boundary temperature conditions.
Regards,
Marco.
Old   May 25, 2011, 09:58
bigphil's Avatar
Philip Cardiff
Marco,
Yes the tutorial case is not set-up for showing off the temperature solving capabilities,
you could change one of the boundary conditions in "0/T" to see a non-uniform temperature, something like:
    right
      type            fixedValue;
      value           uniform 500;
By the way, d2dt2Schemes in system/fvSchemes should be changed to "Euler" if you want to look at transient stresses:
d2dt2Schemes
default Euler;
Philip
Old   May 26, 2011, 07:35
Default Thermal stress
  #12
Marco Bernardes
Philip,
Thanks a lot! It works fine. Do you have an idea how to show the displacement induced by the thermal expansion?
Regards,
Marco.
Old   May 26, 2011, 07:43
bigphil's Avatar
Philip Cardiff
Marco,
The displacement field D is a combination of the displacements due to the traction/displacement boundary conditions and also the displacement due to thermal expansion.
To view just thermally induced displacements you would have to set your D boundary conditions to something like all of them as traction-free excepts for one or two as symmetry plane or something like that.
Also I would recommend you validate this solver against some sort of analytical solution, because I am not sure how often it is used.
Philip
Old   May 26, 2011, 07:58
Default Displacement
  #14
Marco Bernardes
Dear Philip,
I will do that.
Thank you again,
Marco.
Old   July 14, 2011, 09:13
Default compactNormalStress in solidDisplacementFoam
  #15
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear Philip,
Thanks a lot for the info.
Regarding the solidDisplacementFoam solver, there is a switch called "compactNormalStress", which controls the way the "divSigmaExp" vector field is calculated. I would like to know what does this switch represent in physical terms?
This switch is set to 'yes' in the solver plate with hole example.
I would like to know also if there are any plasticity implementations available for that solver.
Thanks a lot for any help!
Hisham
Hisham is offline   Reply With Quote
Old   July 14, 2011, 10:35
bigphil's Avatar
Philip Cardiff
Hi Hisham,
divSigmaExp seems to be the portion of div(sigma) which is treated explicitly. I am not too familiar with this solver (I use stress solvers based on newStressedFoam in OpenFOAM extend). I am not quite sure what difference the compactNormalStress makes, it seems to just be a slightly different way of calculating the explicit portion of the divergence of sigma. When it is set to yes it seems to be doing the same as newStressedFoam. I would recommend you run a few test cases with it on and off to see how it might effect the results.
As regards plasticity, here in UCD (http://adhesion.ucd.ie/openfoam) solid stress plasticity solvers and material models have been developed, but as yet they have not been released into OpenFOAM extend (I imagine they will be included at some stage). These solvers are based around the newStressedFoam solver.
You could contact Prof. Ivankovic at UCD asking nicely to have access to them, or maybe some sort of collaboration.
Hope it helps,
Philip
Old   July 14, 2011, 10:59
Hisham's Avatar
Hisham Elsafti
Hi Philip
Thanks a million for your quick and efficient response
I will explore the OF extended project (read about it a while ago and seemed to have forgotten about it)
I will review Prof. Ivankovic publications then I'll contact him with less ignorance
Thanks again
Hisham
Old   July 20, 2015, 12:48
  #18
mismichael is on a distinguished road
What if in this case I would like to add water cooling at one side of the plate and heat flux at the other side?
I would like to simulate stresses inside the solid plate in this case.
Thank you.
mismichael is offline   Reply With Quote
Old   July 20, 2015, 22:24
bigphil's Avatar
Philip Cardiff
Originally Posted by mismichael View Post
Thank you.
You have a couple of options; if the local convection currents within the fluid are important then I believe the conjugate heat transfer solvers in OpenFOAM should be a good starting point; alternatively, the fluid could be approximated as a "Newton's law of cooling" style boundary condition for the temperature equation in the solid, so you would not need to directly model the fluid.
Philip
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Thermal stress analysis with heat flux boundary condition cvasse OpenFOAM Running, Solving & CFD 0 March 20, 2018 09:46
2—way FSI with heat transfer ronggehejiumeizuiguo Main CFD Forum 0 June 7, 2015 01:36
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
