[swak4Foam] Error installing swak4Foam
Like Tree26Likes
Old   March 18, 2014, 05:18
Sita Drost
sita is on a distinguished road
Dear Bernhard,
Sorry to bother you again. I had problems with compiling simpleFunctionObjects under OpenFOAM-1.6-ext, apparently due to an incomplete OF installation. Therefore, I decided to upgrade to foam-extend-3.0 with swak4foam_2.x. Installation of foam-extend-3.0 seems all right, but when I try to compile swak4foam, it terminates with errors like
In file included from helpers/switchableNotImplemented.C:43:0:
helpers/switchableNotImplemented.H:47:19: fatal error: error.H: No such file or directory
In file included from helpers/printSwakVersion.C:43:0:
helpers/printSwakVersion.H:46:21: fatal error: Pstream.H: No such file or directory
In file included from helpers/DebugOStream.C:37:0:
helpers/DebugOStream.H:55:21: fatal error: Pstream.H: No such file or directorycompilation terminated.
make: *** [Make/linux64GccDPOpt/DebugOStream.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [Make/linux64GccDPOpt/switchableNotImplemented.o] Error 1
make: *** [Make/linux64GccDPOpt/printSwakVersion.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
And yes, I read the README and searched the MessageBoard, but I couldn't find the same error (of course there are similar errors, but I'm afraid I'm not a sufficiently advanced OF user to figure out a solution from that...).
Thanks in advance for your help!
Best Sita
sita is offline   Reply With Quote
Old   March 19, 2014, 18:35
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by sita View Post
Dear Bernhard,
Best Sita
If error.H and Pstream.H are missing then there is something fundamental wrong. Check whether the link $FOAM_SRC/foam/lnInclude/error.H is there
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   March 22, 2014, 13:06
Retired Super Moderator
Bruno Santos
Greetings to all!
I'm currently compiling a list of known errors and related solutions. This particular issue is now explained here: http://openfoamwiki.net/index.php/In...e_or_directory
Best regards,
Bruno
Old   March 24, 2014, 04:08
Sita Drost
Hi Bernhard, Bruno,
Thanks for your help!
In the meantime I'm back at OpenFOAM-1.6-ext and simpleFunctionObjects, and I now see what's causing my problems there: files that are normally located in /usr/include (like <sys/cdefs.h>, etc.) are located in /usr/include/x86_64-linux-gnu on my system (Ubuntu 12.04 LTS, 64 bits).
So it seems to be not really OpenFOAM related, but maybe you can still help me: how do I tell my computer where to look for these files?
Kind regards,
Sita
Update: adding the correct path to Make/options seems to work, but gives the error below:
cc1plus: error: unrecognised debug output level "nu"
cc1plus: error: unrecognised debug output level "nu"cc1plus: error: unrecognised debug output level "nu"
make: *** [Make/linux64GccDPOpt/SolverInfo.o] Error 1
make: *** [Make/linux64GccDPOpt/simpleFunctionObject.o] Error 1
make: *** [Make/linux64GccDPOpt/simpleDataFunctionObject.o] Error 1
make: *** [Make/linux64GccDPOpt/timelineFunctionObject.o] Error 1
Old   March 25, 2014, 09:55
Assistant Moderator
Bernhard Gschaider
Hi Bernhard, Bruno,
Kind regards,
Sita
Look at the options your added (or the compiler command line that is printed). My guess is that there is somewhere a -Dnu there
Old   March 28, 2014, 08:45
Default Error when installing swak4foam for foam extend 3.0
  #106
Miguel Nóbrega
mnobrega is on a distinguished road
this post was moved to a new Thread
Basic Error when installing swak4foam with foam extend 3.0
mnobrega is offline   Reply With Quote
Old   March 31, 2014, 04:28
Sita Drost
Great, everything seems to work now: foam-extend-3.0 and swak4foam-2.x both compiled without errors. I didn't try swak4foam yet, but foam-extend-3.0 runs without problems. Everyone, thanks for your help!
Sita
Old   May 16, 2014, 09:30
Default Swak4Foam 0.3.0 on foam-extend-3.0 and Opensuse 12.2
  #108
Markus Rehm
markusrehm is on a distinguished road
I am struggeling with the installation of swak4Foam with foam-extend-3.0.
I used this source:
https://github.com/Unofficial-Extend-Project-Mirror/openfoam-extend-Breeder2.0-libraries-swak4Foam
and get the following error
/Allwmake
Previously compiled for OpenFOAM 3.0
No file 'swakConfiguration'. Python etc won't work. See README for details
Checking swak4Foam-version and generating file
Swak version is 0.3.0
Bison is version 2.5
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 3 Minor 0 Patch -1 (-1 == x)
No change to swak4FoamParsers/foamVersion4swak.H
WM_NCOMPPROCS 8 will cause race conditions with the grammars. Resetting to 3 for this library
SOURCE=repositories/SurfacesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64Gcc47DPOpt    -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/finiteVolume/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/sampling/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/fileFormats/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/triSurface/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/surfMesh/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/lagrangian/basic/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/SurfacesRepository.o
SOURCE=repositories/MeshesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64Gcc47DPOpt      -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/finiteVolume/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/sampling/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/fileFormats/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/triSurface/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/surfMesh/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/lagrangian/basic/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/MeshesRepository.o
SOURCE=repositories/GlobalVariablesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64Gcc47DPOpt     -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/finiteVolume/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/sampling/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/fileFormats/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/triSurface/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/surfMesh/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/lagrangian/basic/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude -I/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/GlobalVariablesRepository.o
repositories/SurfacesRepository.C:45:9: error: invalid use of template-name ‘Foam::surfaceWriter’ without an argument list
repositories/SurfacesRepository.C: In member function ‘Foam::sampledSurface& Foam::SurfacesRepository::getSurface(const Foam::dictionary&, const Foam::fvMesh&)’:
repositories/SurfacesRepository.C:169:21: error: ‘scalarSurfaceWriter’ was not declared in this scope
repositories/SurfacesRepository.C:169:40: error: template argument 1 is invalid
repositories/SurfacesRepository.C:169:51: error: invalid type in declaration before ‘(’ token
repositories/SurfacesRepository.C:170:17: error: ‘scalarSurfaceWriter’ is not a class or namespace
repositories/SurfacesRepository.C:182:26: error: base operand of ‘->’ is not a pointer
repositories/SurfacesRepository.C: In member function ‘virtual bool Foam::SurfacesRepository::writeData(Foam::Ostream&) const’:
repositories/SurfacesRepository.C:211:17: error: ‘scalarSurfaceWriter’ was not declared in this scope
repositories/SurfacesRepository.C:211:36: error: template argument 1 is invalid
repositories/SurfacesRepository.C:211:47: error: invalid type in declaration before ‘(’ token
repositories/SurfacesRepository.C:212:13: error: ‘scalarSurfaceWriter’ is not a class or namespace
repositories/SurfacesRepository.C:215:18: error: base operand of ‘->’ is not a pointer
repositories/MeshesRepository.C: In member function ‘Foam::fvMesh& Foam::MeshesRepository::addCoupledMesh(const Foam::word&, const Foam::word&, const Foam::word&)’:
repositories/MeshesRepository.C:189:55: error: ‘class Foam::HashPtrTable<Foam::fvMesh, Foam::word>’ has no member named ‘sortedToc’
repositories/MeshesRepository.C: In member function ‘Foam::scalar Foam::MeshesRepository::setTime(const Foam::word&, Foam::scalar, Foam::label)’:
repositories/MeshesRepository.C:299:59: error: no matching function for call to ‘Foam::HashTable<Foam::regIOobject*>::HashTable(Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>)’
repositories/MeshesRepository.C:299:59: note: candidates are:
In file included from /home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.H:456:0,
                 from /home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashPtrTable.H:39,
                 from /home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/PtrMap.H:38,
                 from repositories/MeshesRepository.H:50,
                 from repositories/MeshesRepository.C:37:
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:110:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::Xfer<Foam::HashTable<T, Key, Hash> >&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:110:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::Xfer<Foam::HashTable<Foam::regIOobject*> >&’
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:84:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::HashTable<T, Key, Hash>&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:84:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::HashTable<Foam::regIOobject*>&’
In file included from /home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:646:0,
                 from /home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.H:456,
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::Istream&, Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int]
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::Istream&’
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:62:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int]
/home/mrehm/OpenFOAM/OpenFOAM-extend-3.0/src/OpenFOAM/lnInclude/HashTable.C:62:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::label {aka int}’
make: *** [Make/linux64Gcc47DPOpt/SurfacesRepository.o] Fehler 1
make: *** Warte auf noch nicht beendete Prozesse...
make: *** [Make/linux64Gcc47DPOpt/MeshesRepository.o] Fehler 1
Any help is appreciated.
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   May 16, 2014, 15:24
Bruno Santos
Greetings Markus,
A few questions:
  1. What installation instructions did you follow for installing foam-extend 3.0? I ask this because the path you have is not the standard one.
  2. Are you certain that foam-extend 3.0 is properly installed and working?
  3. It's possible that your machine is very powerful and has triggered a race condition. To try and fix it, run the following command within the swak4Foam folder:
    wclean all
    unset WM_NCOMPPROCS
    ./Allwmake > log.make 2>&1
    Essential the above commands will clean up the swak4Foam build, disable the multi-core building (takes a while longer to build, but at least it should work) and run Allwmake twice, so that at the end of the second run, you have a summary of the installation. Does this solve the problem?
Best regards,
Bruno
Old   May 19, 2014, 03:46
Markus Rehm
Hi Bruno,
thank you very much for your hints. Unfortunately the error persists.
But you are right, I had some trouble installing the extend-3.0-Version and changed some folders. However, it does run fine up to now, except SWAK.
Maybe I should do a clean reinstall.
Thank you, anyway.
Regards, Markus.
Old   May 20, 2014, 12:28
Assistant Moderator
Bernhard Gschaider
Originally Posted by markusrehm View Post
Hi Bruno,
Thank you, anyway.
Regards, Markus.
My recommendation is to compile swak from the ./Allmake.stage5-script in the ThirdParty-folder of foam-extend-3
I notice that your compiler calls don't have -DFOAM_DEV. That is used by swak to distinguish between OpenFOAM and Foam-Extend (foam-extend should set this automatically)
Old   June 4, 2014, 03:19
Unhappy Swak4Foam 0.2.3 installation error
  #112
Anonymous
Hi123 is on a distinguished road
I am encountering problems in installing swak4Foam 0.2.3 for OF2.3.0.
Bison 2.7.12
Flex2.5.37
gcc 4.6.2
I have attached the texts that displayed while ./Allwmake it as a docx file.
Pls help me for the same.
Thanks in advance
Hi123 is offline   Reply With Quote
Old   June 4, 2014, 03:33
Markus Rehm
Hi Bernhard,
thank's for the hint. That did help!
Both variables -DFOAM_DEV and -FOAM_DEV were not set. But after setting it manually it worked.
Regards, Markus.
Old   June 4, 2014, 05:07
Assistant Moderator
Bernhard Gschaider
Originally Posted by Hi123 View Post
Bison 2.7.12
Flex2.5.37
gcc 4.6.2
Thanks in advance
0.2.3 is over a year old. It knows nothing about OF 2.3. Use the latest release version and if you still have problems we can talk
Old   June 11, 2014, 04:08
Default Bison 2.3 and installation
  #115
Belki is on a distinguished road
Hello everyone,
as you might expect, I am also having problem installing swak4foam, on a cluster.
First of all, the versions installed are:
OpenFoam 2.1.0
Bison 2.3
Flex 2.5.35
swak4Foam 0.3.0
It compiles until it yields:
../FieldValueExpressionParser.yy:467.25-29: syntax error, unexpected type, expecting string or identifier
mv: cannot stat `*.tab.cc': No such file or directory
sed: can't read location.hh: No such file or directory
mv: cannot stat `location.hh': No such file or directory
mv: cannot stat `stack.hh': No such file or directory
mv: cannot stat `position.hh': No such file or directory
sed: can't read FieldValueExpressionParser.tab.hh: No such file or directory
mv: cannot stat `*.hh': No such file or directory
g++: Make/linux64Gcc45DPOpt/FieldValueExpressionParser.C: No such file or directory
g++: no input files
make: *** [Make/linux64Gcc45DPOpt/FieldValueExpressionParser.o] Error 1
I was thinking it could come from the version of Bison as it is a .yy file which gets an error but it is stated that only plugins are not supposed to work with the 2.3 version.
Any ideas on how to fix this?
Thanks in advance,
Regards,
Bruno
Belki is offline   Reply With Quote
Old   June 11, 2014, 04:41
Assistant Moderator
Bernhard Gschaider
Originally Posted by Belki View Post
Hello everyone,
OpenFoam 2.1.0
Bison 2.3
Flex 2.5.35
swak4Foam 0.3.0
Thanks in advance,
Regards,
Bruno
2.3 is too old to compile swak4Foam. But the script Libraries/Allwmake tests for that and ends with an error message. Seems like you set the variable USE_OLD_BISON to bypass that. Only chance to get swak to run is to install a newer version of bison (preferably 2.7, but NOT 3.0). The development version (the one you pull with hg http://openfoamwiki.net/index.php/Co...am#Development) has a script maintainanceScripts/compileRequirements.sh that compiles a version of bison that is used only for swak4Foam
Old   June 11, 2014, 04:49
Hello Bernhard,
Thank you very much for the quick answer.
Unfortuantely, I do not think I will be able to make the IT guys update the Bison version on the whole cluster as I am only a master thesis student but I might be able to put it on one of the work stations.
Hence, my next question:
Is Bison only used to compile swak4Foam and not used anymore once it is installed? i.e. could I compile swak4Foam on the only machine which has Bison 2.7 and then run a parallel case on other machines which have Bison 2.3?
Thanks again for your patience,
Regards,
Bruno
Old   June 11, 2014, 04:58
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
Regards,
Bruno
It's only needed for compilation. What the script described above does is compile it locally, install into the directory swak-sources and use it ONLY during compilation. No root-rights required for this.
If your admins also do not feel like installing mercurial: the last link in section "Tarballs" on the swak-page should get the current dev-version
Old   June 11, 2014, 05:42
Thank you, Bernhard.
Old   November 5, 2014, 04:13
Mahdi
Masgar is on a distinguished road
Dear All,
I am trying to install swak4FOAM on my OpenFOAM1.6ext, but it gives the error:
lnInclude/swak.H:89:5: note: in expansion of macro ‘FOAM_VERSION4SWAK’
#if FOAM_VERSION4SWAK < VERSION_NR(1,7,0)
make: *** [Make/linux64GccDPOpt/exprString.o] Error 1
Could you please let me know how I could make it work?
Thanks in advance and Best,
Masgar is offline   Reply With Quote
compile error, swak4foam
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
[swak4Foam] and twoPhaseEulerFoam mnikku OpenFOAM Community Contributions 1 February 19, 2016 05:21
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 10:31
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
