[swak4Foam] how to install the funkySetFields of version 2.0.1
Old   November 5, 2011, 00:39
Default how to install the funkySetFields of version 2.0.1
zakir
zakir hussain is on a distinguished road
hello everybody
The first qustion is that how to get the funkySetFields of version 2.0.x?The next question is how to install the svn? when i run the commond :
sudo apt-get install subversion it appeared that :
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/cn.archive.ubuntu.com_ubuntu_dists_natty_main_bina ry-i386_Packages
How can I deal with my problem?
I have refer to the website:http://openfoamwiki.net/index.php/Co...funkySetFields
But without any progress.
Thanks.
zakir hussain is offline   Reply With Quote
Old   November 5, 2011, 03:00
Retired Super Moderator
Bruno Santos
Greetings Zakir and welcome to the forum!
Quoting the funkySetFields page:
Note: Active development of funkySetFields now takes place in swak4Foam  so please have a look there for more up-to-date versions. Support for  this version of funkySetFields is discontinued with OpenFOAM 2.0.
As for the error message you are getting, by googling with the keywords:
Ubuntu Problem with MergeList /var/lib/apt
I got this as first result: http://www.ihaveapc.com/2011/05/how-...-ubuntu-11-04/
Best regards,
Bruno
Old   November 5, 2011, 06:38
Default about the swak4Foam
zakir
hello wyldckat
Thank you for your help.But I can't download the swak4Foam of version 2.0 because i don't have the svn. Could you upload it here?
Regards
zakir.
Old   November 5, 2011, 07:13
Bruno Santos
Hi Zakir,
Sorry about that, I forgot to give you the direct link.. you can download a tarball yourself from here: http://openfoam-extend.svn.sourcefor...ies/swak4Foam/ - click on the link "Download GNU tarball" on that page.
To unpack the downloaded tarball, run:
tar -xzf openfoam-extend-swak4Foam.tar.gz
Best regards,
Bruno
Old   November 5, 2011, 08:55
Post
zakir
hi Bruno
Thank you for your help. I have download swak4Foam sucessfully. but when i compiled
the Foam, it occured that :
/bin/sh: bison:not found
How can i deal with the problem?
I am new to linux.
Regard.
zakir
Old   November 5, 2011, 13:00
Bruno Santos
Hi Zakir,
Run:
sudo apt-get install bison
Best regards,
Bruno
Old   April 12, 2013, 20:17
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Originally Posted by wyldckat View Post
Hi Zakir,
Best regards,
Bruno
Hey, i am not able to download from that link the FunkySetsField for openFOAM 2.0.x or 2.1.x is there any other way i can get to it even the SGV file is not opening..!!! can u upload the Tar.gz file here by any chance
thanks a lot
hasan.
Alhasan is offline   Reply With Quote
Old   April 12, 2013, 20:18
Unhappy
Alhasan's Avatar
Hasan K.J.
Hi Zakir,
Best regards,
Bruno
Hey, i am not able to download from that link the FunkySetsField for openFOAM 2.0.x or 2.1.x is there any other way i can get to it even the SVN file is not opening..!!! can u upload the Tar.gz file here by any chance or mail or someother link
thanks a lot
hasan.
Old   April 13, 2013, 04:34
Assistant Moderator
Bernhard Gschaider
thanks a lot
hasan.
Have a look at http://openfoamwiki.net/index.php/Co...am#Downloading why this currently is not possible and what the alternatives are
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 13, 2013, 06:47
Alhasan's Avatar
Hasan K.J.
Hey,
every where it says swak4Foam and i am not able to download from the openFOAM wiki link on the SVN https://openfoam-extend.svn.sourcefo...ies/swak4Foam/ or on thehttp://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Breeder_2.0/libraries/swak4Foam/ Download GNU tarball
that is why i had asked if u could upload is there any other way
thank you,
hasan.
Old   April 13, 2013, 16:09
Assistant Moderator
Bernhard Gschaider
Hey,
thank you,
hasan.
Please read a bit further down on the link I gave you "Temporary download to replace closes SVN" .... the links to those tarballs work
Old   April 13, 2013, 16:29
Alhasan's Avatar
Hasan K.J.
Thanks a LOT... atlast... thanks for mentioning it.... i have ADD .. i would have never figured out that link if u dint ..
thanks,
hasan.
Old   April 14, 2013, 06:06
Assistant Moderator
Bernhard Gschaider
thanks,
hasan.
If the text was unclear please make a suggestion to improve it. If it wasn't please make it a habit to read paragraphs till the end. It's a bit frustrating to go through the effort of writing supplying that stuff and then having to push people at it as well
Old   July 18, 2013, 04:47
Kshitij kunte
k.kshitij is on a distinguished road
Hi All,
I'm trying to install Swak4Foam_2.x_release_0.2.3 for OpenFOAM-2.2.0 and getting the following error,
HTML Code:
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Bison is version 2.5
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 2 Patch 0 (-1 == x)
No change to swak4FoamParsers/foamVersion4swak.H
SOURCE=repositories/MeshesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt       -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/surfMesh/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MeshesRepository.o
repositories/MeshesRepository.C: In member function ‘Foam::scalar Foam::MeshesRepository::setTime(const Foam::word&, Foam::scalar, Foam::label)’:
repositories/MeshesRepository.C:299:59: error: no matching function for call to ‘Foam::HashTable<Foam::regIOobject*>::HashTable(Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>)’
repositories/MeshesRepository.C:299:59: note: candidates are:
In file included from /home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.H:555:0,
                 from /home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashPtrTable.H:39,
                 from /home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/PtrMap.H:38,
                 from repositories/MeshesRepository.H:50,
                 from repositories/MeshesRepository.C:37:
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:79:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::Xfer<Foam::HashTable<T, Key, Hash> >&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:79:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::Xfer<Foam::HashTable<Foam::regIOobject*> >&’
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:55:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::HashTable<T, Key, Hash>&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:55:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::HashTable<Foam::regIOobject*>&’
In file included from /home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:612:0,
                 from /home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.H:555,
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::Istream&, Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int]
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::Istream&’
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:35:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int]
/home/euler/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/HashTable.C:35:1: note:   no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::label {aka int}’
make: *** [Make/linux64GccDPOpt/MeshesRepository.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
can anybody tell me what is going wrong.
k.kshitij is offline   Reply With Quote
Old   July 18, 2013, 05:49
Assistant Moderator
Bernhard Gschaider
Originally Posted by k.kshitij View Post
Hi All,
HTML Code:
Yeah. Immediately after the release of 2.2.0 OpenCFD in their infinite wisdom changed an essential part of the API in the GIT-version (which I used for the development). Go to the offending line (repositories/MeshesRepository.C:299) and remove or add const (I can't remember which).
This has already been reported a number of times and has already been taken care of in the release 0.2.4
funkysetfields
[OpenFOAM.org] error happened when I install paraView5.4 zxzx OpenFOAM Installation 3 September 26, 2018 17:10
libz.so.1: no version information available dmaz OpenFOAM Running, Solving & CFD 3 January 4, 2015 16:54
Convergence Problems using Spalart Allmaras recnice OpenFOAM Running, Solving & CFD 3 October 9, 2013 12:19
compressible low speed channel flow -Ali OpenFOAM Running, Solving & CFD 11 May 9, 2013 07:40
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
