[cfMesh] and Multi Region Meshing
Like Tree13Likes
  • 9 Post By starykov
  • 3 Post By starykov
  • 1 Post By starykov
Old   April 13, 2015, 05:19
Default and Multi Region Meshing
amine
aminem is on a distinguished road
Can I use cfMesh for Multi Region Meshing like snappyHexMesh?
Thanks
aminem is offline   Reply With Quote
Old   July 10, 2015, 06:45
Oleksiy Starykov
starykov is on a distinguished road
You can.
Please find a sample case in attachment, the Allrun-file shows you the way to make the multi-region mesh.
starykov is offline   Reply With Quote
Old   June 5, 2017, 15:37
Anonymous
thegame24 is on a distinguished road
Originally Posted by starykov View Post
You can.
Hi.
I think the file attached has different patches, as in, different walls are defined. What should I do to define separate regions (volumes) in the mesh.
I am a beginner here, so please correct me if I'm wrong.
thegame24 is offline   Reply With Quote
Old   June 6, 2017, 02:39
Oleksiy Starykov
the multi-regions meshing algorithm is self-explained in Allrun-script, but I can explain it to you.
First you need to create mesh for each region. Since cfmesh has no direct possibility for doing this, you can create two cases and generate mesh for each of them (with custom meshDict-settings):
cartesianMesh -case cases/pipewall
Afterwards you need to copy generated meshes to the constant/polyMesh directory in order to use them as region meshes:
cp -r cases/pipe/constant/polyMesh/ constant/pipe
cp -r cases/pipewall/constant/polyMesh/ constant/pipewall
Now you need to correctly adress the field mappings etc. This is done via changeDictionary tool, using the system/changeDictionaryDict for each region. In system/pipe/changeDictionaryDict you have:
dictionaryReplacement
boundary
   pipe_to_pipewall
      type mappedWall;
      sampleMode nearestPatchFace;
      sampleRegion pipewall;
      samplePatch pipewall_to_pipe;
That means that in the file constant/polyMesh/pipe/boundary the entry pipe_to_pipewall will be modified with these settings. You define this boundary as mapped on the neighboring region that has name pipewall, and the neighboring patch has name pipewall_to_pipe.
You need to create such mappings for all inter-region boundaries in your system.
Of course you need to properly set the heat transfer conditions at the boundaries, usually via changeDictionaryDict files.
spitchers, rando_foamer and requou like this.
Old   June 6, 2017, 02:44
Anonymous
Thanks. You saved me.
Old   June 6, 2018, 09:26
anonymous
simrego is on a distinguished road
Hi!
I think you should use nearestPatchFaceAMI, since your mesh at the interface is not conform.
simrego is offline   Reply With Quote
Old   June 7, 2018, 01:39
Oleksiy Starykov
Yes, you are right.
Old   March 7, 2019, 07:01
Bastian Heitkötter
Bastian@MM is on a distinguished road
Hi starykov,
I have a question about MultiRegion-Meshing with cfMesh. I have a case with 6 region andbe able to mesh them. But to run chtMultiRegionSimpleFoam I need the cellToRegion file in 0. How did you create it?
Bastian@MM is offline   Reply With Quote
Old   December 23, 2020, 09:19
Default it doesn't work
julien
julieng is on a distinguished road
I try to mesh multiregions, I found this topic and I try the case attached by starykov. When I do the Allrun command it complains with
HTML Code:
|  \\    /   O peration     | Version:  5.x                                   |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 5.x-963176928289
Exec   : C:/PROGRA~1/BLUECF~1/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin/changeDictionary.exe -region pipe
Date   : Dec 23 2020
Time   : 15:04:35
Host   : "PC_JULIEN"
PID    : 9648
I/O    : uncollated
Case   : C:/PROGRA~1/BLUECF~1/OFUSER~1/run/CFMESH~1/forum/tubeStl
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh pipe for time = 0
Read dictionary changeDictionaryDict with replacements for dictionaries 1(dictionaryReplacement)
Reading polyMesh/boundary file to extract patch names
Loaded dictionary boundary with entries
3
minY
maxY
pipe_to_pipewall
Replacing entries in dictionary dictionaryReplacement
Loading dictionary dictionaryReplacement
--> FOAM FATAL ERROR:
cannot find file "C:/PROGRA~1/BLUECF~1/OFUSER~1/run/CFMESH~1/forum/tubeStl/0/pipe/dictionaryReplacement"
    From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 522.
FOAM exiting
It is a problem with changeDictionnaryDict file I think but I don't know how to resolve this. I see also that there is no directory constant/polyMesh created. Maybe the problem comes from to this.
I work with bluecorecfd on windows 10.
Best regards
julieng is offline   Reply With Quote
Old   December 23, 2020, 15:15
Oleksiy Starykov
for this particular problem you have to remove that dictionaryReplacement with
{} parentheses in the dict file. The file format changed in the meantime.
But there are other changes, you have to adjust your files. Look at the heater-tutorials in the heatTransfer directory and update them accordingly.
Originally Posted by julieng View Post
YatengQ likes this.
Old   March 6, 2022, 07:49
Default Error with tubeStl case
  #11
Aditya
Adibantwal is on a distinguished road
Hi, after running Allrun with your case, it gives this error:
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _f3950763fe-20191219 OPENFOAM=1912
Arch   : "LSB;label=32;scalar=64"
Exec   : changeDictionary -region pipewall
Date   : Mar 06 2022
Time   : 18:17:54
Host   : LAPTOP-TT50BSP8
PID    : 21018
I/O    : uncollated
Case   : /mnt/c/Users/Aditya/Desktop/learrn/tubeStl/tubeStl
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
Create time
Create mesh pipewall for time = 0
Loaded dictionary boundary with entries 4(minY maxY wall pipewall_to_pipe)
--> FOAM Warning :
    From function int main(int, char**)
    in file changeDictionary.C at line 709
    Requested field to change dictionaryReplacement does not exist in "/mnt/c/Users/Aditya/Desktop/learrn/tubeStl/tubeStl/0/pipewall"
End
Adibantwal is offline   Reply With Quote
Old   July 26, 2022, 02:50
itsme_kit is on a distinguished road
Yes, you are right.
Hi starykov
Though we apply nearestPatchFaceAMI in sampleMode (fields will be mapped in those two different regions in the process of simulation), the generated mesh in Paraview is still not conform, is there a way of creating a conformal mesh in this case in cfmesh?
Looking forward to hearing from you.
Best Regards,
Kit
itsme_kit is offline   Reply With Quote
[snappyHexMesh] New multi region meshing tutorial with sHM Tobi OpenFOAM Meshing & Mesh Conversion 0 November 24, 2014 17:42
[snappyHexMesh] Multi Region Meshing bruce OpenFOAM Meshing & Mesh Conversion 12 July 31, 2013 10:09
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[snappyHexMesh] Multi Region Meshing with sHM marango OpenFOAM Meshing & Mesh Conversion 3 March 27, 2012 00:51
Multi region meshing noob@cfd Siemens 2 March 26, 2012 12:32
