[SOWFA] SOWFA installation Error
Old   February 9, 2016, 14:25
Question SOWFA installation Error
Mohsen
mohsen.boojari is on a distinguished road
Hi everyone,
I'm trying to install and use the SOWFA code but i'm facing this error :
Making dependency list for source file pisoFoamTurbine.C
could not open file horizontalAxisWindTurbinesALM.H for source file pisoFoamTurbine.C
SOURCE=pisoFoamTurbine.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam222/src/transportModels -I/opt/openfoam222/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam222/src/finiteVolume/lnInclude -I/home/mohsen/OpenFOAM/mohsen-2.2.2/src/turbineModels/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pisoFoamTurbine.o
pisoFoamTurbine.C:38:43: fatal error: horizontalAxisWindTurbinesALM.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/pisoFoamTurbine.o] Error 1
i can't underestand why it can not open the
file!!
any Idea about what's the cause of my problem and the solution for it??
thank you all
mohsen.boojari is offline   Reply With Quote
Old   April 13, 2016, 11:53
Fatih Ertinaz
fertinaz is on a distinguished road
Hi mohsen,
I don't know if you could solve this problem since February but i am gonna write a few comments anyway just in case that there might be others having the same issue.
It looks like the package you downloaded is missing the file you mentioned
Open the Allwmake file in Sowfa root folder and try compiling step by step because there are some other missing files as well. You can find them in the Sowfa's git repo.
Hope this helps
Fatih
fertinaz is offline   Reply With Quote
compilation error, pisofoam, sowfa
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
