[cfMesh] renameBoundary
Like Tree2Likes
  • 2 Post By indy07cz
Old   March 31, 2016, 04:53
Default renameBoundary
Ervin Adorean
adorean is on a distinguished road
Is it only me, or cfMesh v1.1.1 windows and cfMesh in foam-extend 3.2 only renames boundaries with specified newName, but does not change type, with the one specified in newType?
All types are wall in the resulting constant/polyMesh/boundary file, no matter what (type) one specifies in newPatchNames subdictionary.
For reference, cfMesh cartesianMesh tutorial "elbow_90degree".
Thank you!
Best regards,
Ervin
adorean is offline   Reply With Quote
Old   March 31, 2016, 05:43
Ervin Adorean
Well, I found the culprit;
in the meshDict, one needs to put "type" as in the UserGuide, not "newType" as in the tutorial file.
Best regards,
Ervin
Old   April 7, 2016, 09:34
benoit Augier
baugier is on a distinguished road
Hi Ervin,
I have the same issue, but it is not solved by your simple typo change.
The only command working in my case is defaultName. Nothing regarding the type is working. Have you figure something else out?
Best,
Ben
baugier is offline   Reply With Quote
Old   April 8, 2016, 05:15
Ervin Adorean
I really do not understand your statements.
I have given all the necessary details about the issue and the fix, in my 2 posts.
All you have to do is search in the manual and the tutorial (both mentioned in my posts).
Ervin
Old   April 8, 2016, 09:35
benoit Augier
I found my answer in the tutorial you mentionned.
Thanks
Old   February 5, 2020, 04:23
Honza Höll
indy07cz is on a distinguished road
Hi meshers, I have some strange problem with renaming boundaries in the case of fms input file. FMS file is exported from Salome with 5 patches:
5
inlet    wall
outletTG2    wall
privadec    wall
natok    wall
krizeni    wall
Since I need different refinement levels for each of them I can't have 1 geometry for wall. Then I want to have "krizeni|provadec|natok" renamed to staticWall. But here comes the problem defaultName and defaultType doesn't work and I must define each part separately (below).
renameBoundary
    defaultName        staticWall;
    defaultType        wall;
    newPatchNames
        inlet
            newName     inlet;
            type     patch;
        outletTG2
            newName     outletTG2;
            type     patch;
        privadec
            newName     staticWall;
            type     wall;
        natok
            newName     staticWall;
            type     wall;
        krizeni
            newName     staticWall;
            type     wall;
Strange that for STL file everything works fine. So it's not a big problem but maybe a bug? I don't know.
indy07cz is offline   Reply With Quote
Old   February 5, 2020, 10:50
Kmeti Rao
Krao is on a distinguished road
Hi Honza,
Try something like this
"(privadec|natok|krizeni)"
newName staticWall;
type wall;
K. Rao
Krao is offline   Reply With Quote
Old   February 7, 2020, 03:50
Honza Höll
Thank you, already know about this. I wanted to point out, that defaultName and defaultType don't work properly.
Krao and Ollemand like this.
[cfMesh] I should like group and rename patches AFTER meshing pici OpenFOAM Community Contributions 3 August 21, 2015 06:25
