[cfMesh] crash "Could not find a boundary region for vertex"
Like Tree1Likes
  • 1 Post By bennn
Old   July 24, 2017, 04:11
Default crash "Could not find a boundary region for vertex"
benoit paillard
bennn is on a distinguished road
Hi all,
I'm having a weird segfault with cfMesh 1.1 on an aircraft geometry. The case is here : https://www.dropbox.com/s/tsy0qahpkd...sh.tar.gz?dl=0
The last part of the log is :
Extracting edges
--> FOAM Warning : Could not find a boundary region for vertex (5.77236300201 -0.514531104193 4.17864446258)
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  ? at edgeExtractor.C:?
#4  ? in "/usr/lib/x86_64-linux-gnu/libgomp.so.1"
#5  ? in "/lib/x86_64-linux-gnu/libpthread.so.0"
#6  clone in "/lib/x86_64-linux-gnu/libc.so.6"
Segmentation fault (core dumped)
You can get the same result by simply running cartesianMesh in the folder above. I know the geometry is a bit crappy, but it is also why I chose it as a test case...
Any thoughts ? Thanks !
daniyalaltaf likes this.
bennn is offline   Reply With Quote
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Radiation interface hinca CFX 15 January 26, 2014 17:11
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
