[cfMesh] How to create internal faces in cfMesh? |
May 28, 2018, 06:50 |
Dr. Peyman Davvalo Khongar
Rep Power: 8 |
Moi,
I have worked with cfMesh for many years and I found it very stable and fast. The only problem that I have is that, I have never been able to make a good internal face (like baffle faces) using cfMesh. I was wondering if anyone can give me suggestion to create internal faces (zero thickness internal faces) using cfMesh? Let say you have a box which has a face inside it and it is not connected to any faces of the box. Moikka, Peyman |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
