[cfMesh] Compiling cfMesh with OpenFOAM 4.x
Like Tree5Likes
  • 1 Post By wyldckat
  • 2 Post By dkokron
  • 2 Post By wyldckat
Old   October 4, 2016, 15:47
Default Compiling cfMesh with OpenFOAM 4.x
Dan Kokron
dkokron is on a distinguished road
Originally Posted by wyldckat View Post
If you're looking for the source code of cfMesh (the non-Pro version), it's still available here: https://sourceforge.net/projects/cfmesh/ - according to their tweets, they updated it recently for OpenFOAM 4.0, it's on the "development" branch.
Following up on Bruno's suggestion that cfMesh has been updated to work with OpenFOAM-4.x, I installed the development release.
git clone git://git.code.sf.net/p/cfmesh/code cfmesh
and tried to build it against my installation of OpenFOAM-4.x. I'm using the Intel-2017.0.098 compiler on a Fedora-24 system.
Here's the compile time error.
icpc -std=c++11 -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 327,654,1125,2289,2304,11062,11074,11076 -O3  -DNoRepository -I../../meshLibrary/lnInclude -I/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/triSurface/lnInclude -I/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/meshTools/lnInclude -I/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/edgeMesh/lnInclude -IlnInclude -I. -I/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude -I/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/OSspecific/POSIX/lnInclude   -fPIC -c FLMAToSurface.C -o Make/linux64IccDPInt32Opt/FLMAToSurface.o
../../meshLibrary/lnInclude/DynListI.H(42): error #373: "void Foam::UList<T>::operator=(const Foam::UList<T> &) [with T=Foam::label={int32_t={int}}]" (declared at line 93 of "/home/dkokron/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/UList.H") is inaccessible
          this->UList<T>::operator=(UList<T>(newData, s));
          detected during:
            instantiation of "void Foam::DynList<T, staticSize>::allocateSize(Foam::label={int32_t={int}}) [with T=Foam::label={int32_t={int}}, staticSize=16]" at line 214
            instantiation of "void Foam::DynList<T, staticSize>::append(const T &) [with T=Foam::label={int32_t={int}}, staticSize=16]" at line 98 of "../../meshLibrary/lnInclude/triSurfPointsI.H"
[ Moderator note: moved these three 3 posts from thread that the quote refers to, as well as added the quote for continuity sake and added code markers to the output. This thread is now ready for discussion on how to compile cfMesh with OpenFOAM 4.x ]
dkokron is offline   Reply With Quote
Old   October 9, 2016, 15:58
Retired Super Moderator
Bruno Santos
Quick answer: You need to checkout the "development" branch. Complete list of commands:
cd cfmesh
git checkout development
export WM_NCOMPPROCS=4
time ./Allwmake > log.make 2>&1
Tobi likes this.
Old   October 10, 2016, 13:53
Dan Kokron
I confirmed that the 'development' branch does indeed build and run under 4.x. I also confirmed essentially zero-diff output for one of my geometries compared with cfMesh-1.1.1 built against OF-3.0+.
Thanks again Bruno.
wyldckat and Tobi like this.
Old   October 11, 2016, 16:26
Bruno Santos
Just a quick note: They have released cfMesh 1.2.1 recently: https://twitter.com/CFieldsHR/status/785774036206755840
#cfMesh now adapted to the latest version of OpenFOAM 4.0 and foam-extend-4.0
Download link: https://sourceforge.net/projects/cfmesh/files/v1.1.2/
franjo_j and mujika like this.
Old   April 6, 2017, 06:43
Giampaolo Cetraro
misklach is on a distinguished road
Hello I've successfully compiled cfMesh-v1.1.2 with OpenFOAM-4.1 and it works very well.
However when I try to mesh something with a smaller cell size I get this error
Create time
Setting root cube size and refinement parameters
Root box (-16.4988893 -17.6854167 -15.189) (16.2691107 15.0825833 17.579)
Requested cell size corresponds to octree level 10
Refining boundary
Refining boundary boxes to the given size
--> FOAM FATAL ERROR:
Negative size requested.
    From function template<class T, Foam::label Offset>
inline void Foam::LongList<T, Offset>::allocateSize(const label)
    in file lnInclude/LongListI.H at line 73.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::meshOctreeCube::findLeaves(Foam::LongList<Foam::meshOctreeCube*, 19>&) const at ??:?
#3  Foam::meshOctreeCube::findLeaves(Foam::LongList<Foam::meshOctreeCube*, 19>&) const at ??:?
#4  Foam::meshOctreeCube::findLeaves(Foam::LongList<Foam::meshOctreeCube*, 19>&) const at ??:?
#5  Foam::meshOctreeCube::findLeaves(Foam::LongList<Foam::meshOctreeCube*, 19>&) const at ??:?
I thought I had too many cells so I tried to compile cfMesh against OpenFOAM-4.1 with WM_LABEL_SIZE=64
Unfortunately I get this compilation error
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16l]’:
lnInclude/helperFunctionsTopologyManipulationI.H:491:34:   required from here
lnInclude/DynListI.H:195:15: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’
     setSize(l.size());
lnInclude/DynListI.H:197:32: error: subscripted value is neither array nor pointer
         this->operator[](i) = l[i];
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6l]’:
lnInclude/helperFunctionsGeometryQueriesI.H:1059:37:   required from here
     setSize(l.size());
make: *** [Make/linux64Gcc62DPInt64Opt/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.o] Error 1
Do you know how to fix this?
Thank you
Giampaolo
misklach is offline   Reply With Quote
Old   August 17, 2017, 21:18
Default OpenFOAM-dev not compiling due to metaDict_
Bernard
berny.tuegs is on a distinguished road
*Edit* I have gone further along in the compilation. The original problem was metaDict_
Here is the list of steps I encountered and what I did to combat them:
1. metaDict_ not declared. Added "IOdictionary.H to polyMeshGen.H
2. The annoying tautology warning can be removed by changing ms.type_ != ms.type_ to ms.type != type_ in meshSubsetI.H
3. edgeMesh has been incorporated into meshTools in OF5 and dev. I did an in-place replacement of -ledgeMesh with nothing
4. Pstream::blocking and Pstream::scheduled have been replaced by Pstream::commsTypes::blocking and Pstream::commsTypes::scheduled - I replaced these
5. My foam compilation was done with WM_LABEL_SIZE=64. This seems to kill the compilation as it can't recognise a list in these circumstances (see Giampalo's error)
6. Set the WM_LABEL_SIZE to 32, meshLibrary compiles, but errors occur straight away once we try and build the executables. I saw the approach proposed by laurent in thread 160757 but that has since changed.
I am thinking of going back to LABEL_SIZE of 64 and trying to sort out the problem there.
I now have heaps more problems after this. First errors start at first program in the rank: cartesian2DMesh. See error message attached.
Any help would be greatly appreciated.
Last edited by berny.tuegs; August 18, 2017 at 01:57. Reason: moved along in compilation
berny.tuegs is offline   Reply With Quote
Old   October 9, 2017, 03:12
Default Compilation of cfMesh works
Stefan Hildenbrand
shildenbrand is on a distinguished road
Following your proposed steps 1,3 and 4 cfMesh compiles now with OF-dev.
shildenbrand is offline   Reply With Quote
Old   November 2, 2017, 16:12
Henning86 is on a distinguished road
Openfoam v1706 will compile with:
git checkout port-v1606+
Henning86 is offline   Reply With Quote
Old   November 6, 2017, 23:29
M. C.
student666 is on a distinguished road
Please, can you give more details how to perform following instructions?...I'm not so skilled at linux compilation.
and
Thanks
student666 is offline   Reply With Quote
Old   November 8, 2017, 17:34
M. C.
I was able to partially compile the library, by fixing point 1 adding to:
../meshLibrary/lnInclude/polyMeshGen.H
#include "polyMeshGenCells.H"
#include "dictionary.H"
#include "IOdictionary.H"
and using the following command:
find ./ -exec sed -i -e 's/Pstream::blocking/Pstream::commsTypes::blocking/' {} \;
find ./ -exec sed -i -e 's/Pstream::scheduled/Pstream::commsTypes::scheduled/' {} \;
now I'm stuck with the following:
utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.C:505:67: error: no matching function for call to ‘eigenVector(Foam::symmTensor&, const double&)’
                             vector normal1 = eigenVector(nt, ev[1]);
utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.C:498:66: error: no matching function for call to ‘eigenVector(Foam::symmTensor&, const double&)’
                             vector normal = eigenVector(nt, ev[2]);
can someone help me to fix this issue?!?
Thanks a lot
I'm compiling on Linux Mint 18.2 with openfoam-dev (last update)
Old   November 10, 2017, 15:03
M. C.
please can somebody helps me with this issue?
utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.C:507:67: error: no matching function for call to ‘eigenVector(Foam::symmTensor&, const double&)’
                             vector normal2 = eigenVector(nt, ev[2]);
In file included from /opt/openfoam-dev/src/OpenFOAM/lnInclude/fieldTypes.H:38:0,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/flipOp.H:40,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/mapDistributeBaseTemplates.C:29,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/mapDistributeBase.H:489,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/FieldMapper.H:35,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.C:26,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.H:408,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/labelField.H:39,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/primitiveFields.H:37,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/pointField.H:36,
                 from /opt/openfoam-dev/src/OpenFOAM/lnInclude/boundBox.H:35,
                 from utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.H:40,
                 from utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.C:29:
/opt/openfoam-dev/src/OpenFOAM/lnInclude/tensor.H:54:8: note: candidate: Foam::vector Foam::eigenVector(const tensor&, Foam::scalar, const vector&, const vector&)
 vector eigenVector
Thanks in advance.
Regards
Old   November 13, 2017, 05:16
Stefan Hildenbrand
I downloaded the latest version in git today and now the source compiles without any modifications from the source.
Old   November 13, 2017, 13:30
M. C.
Are you using ubuntu and opebfoam-dev?
Old   November 13, 2017, 16:15
M. C.
I can't understand, but I'm not able to run the compilation on LinuxMint 18.2.
I used
git clone git://git.code.sf.net/p/cfmesh/code cfmesh-code
but It seems that same version has been downloaded as for same errors occurs.
After fixing point 1,3,4, and ./Allwmake, I got this
wmakeLnInclude: linking include files to ./lnInclude
could not open file foamTime.H for source file utilities/workflowControls/workflowControls.C due to No such file or directory
could not open file foamTime.H for source file utilities/dataConversion/foamToFPMA/fpmaMesh.C due to No such file or directory
could not open file foamTime.H for source file utilities/dataConversion/foamToFPMA/writeMeshFPMA.C due to No such file or directory
could not open file foamTime.H for source file voronoiMesh/voronoiMeshGenerator/voronoiMeshGenerator.C due to No such file or directory
could not open file foamTime.H for source file voronoiMesh/voronoiMeshExtractor/voronoiMeshExtractorCreateMesh.C due to No such file or directory
and that's the error
utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.C: In member function ‘void Foam::tetMeshOptimisation::optimiseBoundaryVolumeOptimizer(Foam::label, bool)’:
 vector eigenVector
/opt/openfoam-dev/src/OpenFOAM/lnInclude/tensor.H:54:8: note:   candidate expects 4 arguments, 2 provided
/opt/openfoam-dev/src/OpenFOAM/lnInclude/tensor.H:65:8: note: candidate: Foam::vector Foam::eigenVector(const symmTensor&, Foam::scalar, const vector&, const vector&)
 vector eigenVector
/opt/openfoam-dev/src/OpenFOAM/lnInclude/tensor.H:65:8: note:   candidate expects 4 arguments, 2 provided
 vector eigenVector
 vector eigenVector
 vector eigenVector
 vector eigenVector
make: *** [Make/linux64GccDPInt32Opt/utilities/smoothers/geometry/meshOptimizer/tetMeshOptimisation/tetMeshOptimisation.o] Error 1
could not open file foamTime.H for source file cartesian2DMesh.C due to No such file or directory
/usr/bin/ld: cannot find -ledgeMesh
/usr/bin/ld: cannot find -lmeshLibrary
collect2: error: ld returned 1 exit status
make[1]: *** [/home/michele/OpenFOAM/michele-dev/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh] Error 1
make: *** [cartesian2DMesh] Error 2
make[1]: *** [/home/michele/OpenFOAM/michele-dev/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Error 1
make: *** [checkSurfaceMesh] Error 2
I attach even the log file of my compilation
Old   November 14, 2017, 02:51
Stefan Hildenbrand
You need to get the development branch, see post #2
Old   November 14, 2017, 14:24
M. C.
Thank you very much,
As the post from Bruno is 1-year old, I thought it was "old"
Regards.
Old   August 15, 2018, 11:26
Zander Meiring
yambanshee is on a distinguished road
Thanks a lot
also getting this issue. Did you manage to solve it?
yambanshee is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
Error compiling DES in OpenFoam v1612+ VisMart OpenFOAM Programming & Development 4 July 18, 2017 09:11
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 19:20
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk kaergaard OpenFOAM Installation 1 June 16, 2011 01:33
