[waves2Foam] Question about the coupling of OceanWave3D and openfoam
Old   December 28, 2015, 10:34
Default Question about the coupling of OceanWave3D and openfoam
Aloha
app1e is on a distinguished road
hi ngj,
i have a question about the coupling of OCW3 and openfoam , it seems that the generated wave is based on stream function wave theory,so is it only applicable to the case when the ratio of water depth to wave length is relatively small?
Thank you in advance
app1e is offline   Reply With Quote
Old   December 28, 2015, 17:41
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Aloha,
The example, yes, is based on stream function wave theory. OCW3D is on the other hand a fully nonlinear solution to the wave problem over an arbitrary bed. I suggest that you consult the release document in waves2Foam and the references stated therein.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 29, 2015, 04:24
Fei Fan
Fanfei is on a distinguished road
Originally Posted by ngj View Post
Hallo Aloha,
Kind regards,
Niels
Hi Niels:
I'm so sorry to trobule you. I have introduced the density item into ke model as you mentioned above. It works, and the wave energy disspation declinded. however, the disspation is not elimilated totally. I test Kirby's experiment. The wave sholud break at point x=12.5m, while in my model, it breaks at the location x=15.2m. For the wave height , it almost keep constant as the water become shallow. so I want to know is there some mistakes in my model or there're some other works i need to do to solve this problem.
Kind Regards
Fan Fei
Fanfei is offline   Reply With Quote
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 JGadelho OpenFOAM Community Contributions 36 April 27, 2024 16:46
[waves2Foam] OceanWave3d coupling in OpenFOAM-4.0.0 amgh OpenFOAM Community Contributions 5 July 3, 2018 15:11
[waves2Foam] compilling wave2Foam in OpenFOAM 4.1 and ubuntu 16.04 Ben UWIHANGANYE OpenFOAM Community Contributions 7 March 27, 2018 01:47
