[waves2Foam] How to couple my FNPT (fully non-linear potential flow theory) code with Wave2Foam?
Old   December 14, 2015, 07:46
Default How to couple my FNPT (fully non-linear potential flow theory) code with Wave2Foam?
nirbhay tiwary
nctiwary is on a distinguished road
Hi all,
I want to couple my FNPT (fully non-linear potential flow theory) code with Wave2Foam.
My FNPT code is generating results in the following form (PFA).fnpt results.txt
So,i want to divide the whole domain into the parts(as shown).
how can i do this.....pls help guys.
With regards
Nirbhay
nctiwary is offline   Reply With Quote
Old   December 15, 2015, 04:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Nirbhay,
Are you aware of the fact that waves2Foam is already coupled with another nonlinear potential flow solver? You might get the needed inspiration for the coupling by looking at the files called oceanWave3D.[C,H] in the source code. This is a coupling through memory, so you likely need to change the interface, if the coupling is through ASCII-files.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 16, 2015, 02:16
Default wave2Foam user manual
nirbhay tiwary
is there any user guide exist for wave2faom?? as https://openfoamwiki.net/index.php/Contrib/waves2Foam link is not sufficient for better understanding.
how waves2foam is different from IHFoam???
Old   December 16, 2015, 03:04
ngj
Good morning,
Currently, the Wiki is the documentation. It is rather elaborate, so it should get you far. Furthermore, notice that there are several scientific references that you could dive into.
The main difference between waves2Foam and IHFoam is that while waves2Foam applies a relaxation zone technique for generation and absorption, then IHFoam applies the generation and absorption directly on the boundary. Both methods have been applied in the literature; sometimes on similar cases.
Kind regards,
Niels
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
udf for 3D laminar fully developed flow salman FLUENT 0 November 9, 2006 21:45
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
