[waves2Foam] Combined Wave = Stokes + current
Like Tree1Likes
  • 1 Post By hjasak
Old   December 10, 2018, 09:30
Default Combined Wave = Stokes + current
Paul Palladium
Fauster is on a distinguished road
Dear Foamer,
I am a bit surprised that there is no easy possibility to add a stokes waves and a current. After reading all the previous posts I tried to use a combination of waves : a Stokes wave and a potential current.
There are some problems :
- a : The wave number calculated by setWaveParameters do not take into account the current velocity. As advised by Niels I tried to recalculate the wave number using the theory (for example using the formula given here : http://www.coastalwiki.org/wiki/Shal...nt_Interaction. For first order wave theory it's kind of easy but it become harder for 5th order waves. As far as I understand only 5 order wave conserve the shape when travelling and because I am interested in seakeeping analysis I would like to used this kind of wave.
- b : If you use a combination of potential current and stokes wave there are some problems when the wave leave the inlet relaxation zone (see picture attached for the waveFlum tutorial). So currently I don't use a inlet relaxation zone.
Are there some solutions to use efficiency wave + current in the waves2foam tool box ?
Thanks in advance,
Paul
Fauster is offline   Reply With Quote
Old   December 11, 2018, 04:38
Hrvoje Jasak
Hi Paul,
Why don't you try stream function waves instead?
Hrv
ngj likes this.
Hrvoje Jasak
Old   December 11, 2018, 14:00
Paul Palladium
Dear Hrvoje Jasak,
Thanks for your help. Because I am not very used to waves modeling I didn't know the existence of stream function waves. After (re)reading the waves2foam manual I manage to set up the waveProperties.input dictionary correctly and got a result. Now I need to go to the source paper to understand properly this kind of waves.
If Niels Gjøl Jacobsen (thank for this wonderful package) takes a look at this post it seems that the Tsoft keyword required for stream waves function is not written in the code Fragment 4.7 of the user manual.
I wish you a good day.
Paul
Old   January 14, 2019, 03:27
XIANGYU SHI
shixiangyu is on a distinguished road
i am using v1712 and i have the same question i tried to change"U" ( internalField uniform (0 0 0) to (speed 0 0), outlet~~outletPhaseMeanVelocity and close awa option, but it not work. if u solved problem tell me plz:d
shixiangyu is offline   Reply With Quote
Old   September 20, 2020, 09:16
zjj
Jianjun Zhou
zjj is on a distinguished road
hello could you please tell me how to get a wave-current using streamfuction wave for detail Thank you!
zjj is offline   Reply With Quote
Old   September 20, 2020, 09:19
zjj
Jianjun Zhou
Originally Posted by Fauster View Post
Dear Hrvoje Jasak,
Paul
hello could you please tell me how to set " wave-current" using streamfuction wave for detail Thank you!
Old   October 11, 2022, 07:14
Arun Kumar
AR91 is on a distinguished road
Originally Posted by hjasak View Post
Hi Paul,
Hrv
This works for most situations with a uniform current, but what if one needs to incorporate a current that varies with water depth, say a linearly shearing current?
Thanks & regards,
Arun.
AR91 is offline   Reply With Quote
Old   October 11, 2022, 07:16
Arun Kumar
From my understanding, you can add a uniform current using the stokesVelocity parameter in the wave theory setup.
Regards,
Arun.
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 14:33
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[waves2Foam] New wave theory - waves + current djpiro OpenFOAM Community Contributions 1 September 4, 2017 10:55
Wave with Current inflow jiko FLOW-3D 0 January 9, 2015 11:08
Max and min wave height variating in time with 5order stokes waves lucaoggi STAR-CCM+ 1 October 31, 2014 07:16
