[swak4Foam] Problems with compilation of swak4foam on Debian with OpenFOAM-7
Like Tree1Likes
  • 1 Post By lth
Old   October 1, 2019, 16:11
Default Problems with compilation of swak4foam on Debian with OpenFOAM-7
Francesca Mangani
FrancescaMangani is on a distinguished road
Good evening,
I'm trying to install swak4foam downloading the source codes but I have problems with the compilation. I'm following instructions from
https://openfoamwiki.net/index.php/I...tion/swak4Foam
When I run the compilation with
./Allwmake > log.make 2>&1
what I obtain in my log file is:
Current OpenFOAM version is .
Previously compiled for OpenFOAM ()
Reading variables from 'swakConfiguration'
Using python2.7 at /usr/bin/python2.7-config for python2
swakConfiguration: riga 34: pkg-config: comando non trovato
Checking swak4Foam-version and generating file
Swak version is 0.4.3
hg info: e7c2de483937 (develop) tip
./Allwmake: riga 70: wmake: comando non trovato
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
(I'm installing swak4foam development version because I think that the others won't work in the latest openfoam-7, but I'm not sure)
If someone help me in some way I would be very grateful to him!
Please ask any information if necessary.
Thanks
Francesca
FrancescaMangani is offline   Reply With Quote
Old   October 2, 2019, 07:24
Piotr Ładyński
piotr.mecht is on a distinguished road
Originally Posted by FrancescaMangani View Post
Good evening,
Check if you have your bulding dependecies satisfied. All libraries with version not older, than required
https://openfoamwiki.net/index.php/I...g_dependencies
E.g. required version of Bison for development version is not often available in linux repos by default (especialy in outdated debian repos), so you have to download it e.g. from gnu bison project website.
piotr.mecht is offline   Reply With Quote
Old   October 2, 2019, 07:55
Francesca Mangani
Thanks for your reply, I've just solved simply running openfoam before running the ./Allwmake command!
However I have some errors maybe due to some wrong directory.... so maybe now the compilation is done but not perfectly complete.
(I uploaded the new Log file)
Maybe this is due to the fact that I have OpenFoam 7 ? and some directories have changed?
Old   October 22, 2019, 15:39
Default Error : wmake: command not found
Ali_Rahnama
peaceshielder is on a distinguished road
Hi everyone!
I'm a newcomer. I installed OF6 and OF7 on Ubuntu 18.04LTS. I've tried many times to install swak4foam. I faced an error like Francesca's first post:
swakConfiguration: line 1: cygpath: command not found
sed: -e expression #1, char 0: no previous regular expression
Swak version is 0.4.2
./Allwmake: line 63: wmake: command not found
Version of bison is 3.4
What should I do?
peaceshielder is offline   Reply With Quote
Old   October 23, 2019, 03:35
Default Installed after lots of attempts
Ali_Rahnama
After many times attempts, it has installed.
I don't know what was the matter, but prior to install, I restart Ubuntu and only run the OpenFoam.
I installed on OF6. I will try to install on OF7 later.
Old   October 22, 2022, 18:14
lth
lth's Avatar
lth
lth is on a distinguished road
Hi All,
I am trying to follow the advice out here and am running openfoam 6 from Ubuntu 18_04
Installed
bison (GNU Bison) 3.0.4, flex 2.6.4, and mercurial (/snap/bin/mercurial)
then:
>>hg clonehttp://hg.code.sf.net/p/openfoam-extend/swak4Foam-u develop
>>cd swak4Foam
>>./maintainanceScripts/compileRequirements.sh
>>./Allwmake (or ./AllwmakeAll > log.AllwmakeAll)
log.AllwmakeAll portions include:
Bison already installed/compiled Bison successfully compiled Lua already installed/compiled Lua successfully compiled Add /home/ltholmes/OpenFOAM/ltholmes-6/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically Current OpenFOAM version is 6. This is a clean install /home/ltholmes/OpenFOAM/ltholmes-6/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' Looking for Python 2 Looking for Python 3 Using our own Lua at /home/ltholmes/OpenFOAM/ltholmes-6/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 202x.yy.0 hg info: 481d96f16780 (develop) tip No 'bear' installed Bison: /home/ltholmes/OpenFOAM/ltholmes-6/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/ltholmes/OpenFOAM/ltholmes-6/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) No swak4FoamParsers/foamVersion4swak.H. Generated << Make/linux64GccDPInt32Opt/repositories/SetsRepository.o
/opt/openfoam6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/repositories/SetsRepository.o' failed Parser library did not compile OK. No sense continuing as everything else depends on it >>
Troubleshooting included multiple attempts and several restarting of Ubuntu and running an openfoam6 case.
Also
>>wmake Utilities/funkySetFields > log.Util_funkySetF
>>ls $FOAM_USER_APPBIN" to check if swak4foam is correctly compiled. (no swak4foam listed)
>>ls $FOAM_USER_LIBBIN" gives: ls: cannot access '/home/ltholmes/OpenFOAM/ltholmes-6/platforms/linux64GccDPInt32Opt/lib and ls': No such file or directory
PS: I installed bear 2.3.11 after posting and re-installed but errors in log remain the same.
Would anyone be able to see the error of my installing ways? I'd love to get funkySetFields working. Thank you, LTH
neelcfd likes this.
Last edited by lth; October 22, 2022 at 20:01. Reason: after original post, I went and installed bear but errrors remain -lth
lth is offline   Reply With Quote
Old   October 23, 2022, 18:45
lth
lth's Avatar
lth
For anyone who faces this issue, it was answered/solved here: [post #172] -LTH
Error installing swak4Foam
installation issue, swak4foam
[swak4Foam] Swak4FOAM installation for OpenFOAM v1806 exx110 OpenFOAM Community Contributions 1 July 5, 2021 20:07
[waves2Foam] Problems with the compilation of the third party dependencies chia87 OpenFOAM Community Contributions 7 May 20, 2017 06:04
[foam-extend.org] problems with openFoam extend 3.0 installation AmirBaqa1987 OpenFOAM Installation 1 December 20, 2016 19:17
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
[waves2Foam] Problems in Operating waveDyMFoam in openfoam 2.3.1 zhxter OpenFOAM Community Contributions 2 May 18, 2015 20:57
