[swak4Foam] swak4Foam on OpenFoam-v2006?
Like Tree11Likes
Old   October 18, 2021, 08:32
Eren
ErenC is on a distinguished road
Originally Posted by gschaider View Post
OK. The problem is that the build-scripts assume that the OBJECT_DIR-variable set up by the wmake-script points to a directory inside the Make-directories in the sources. Then the relative references like "../myflex" work (because they are in the Make-directories). In your case it points to a directory in the /home/erenc/OpenFOAM/OpenFOAM-v2012/build-directory and therefore the relative path doesn't work anymore.
I forgot when wmake makes the decision to compile to outside the sources. Either because some environment variables are missing. Or because things are compiled as root.
You don't compile as root (with sudo) by any chance?
Well, I deleted my files from that PC after recreating the previous post (as I said, it wasn't my PC) so I can't recreate it but I don't remember using the sudo, that might be the solution.
ErenC is offline   Reply With Quote
Old   December 6, 2021, 09:24
Mark Sutkowy
sutkowy1 is on a distinguished road
I'm also having an issue compiling on OF-v2012 with Ubuntu 18.04 for Windows.
I looks like it quits during "wmake libso simpleCloudFunctionObjects" (see attached).
Eventually, it tells me the requirements for library are not satisfied, so not entirely sure whether this is tied to some software dependency or something else. Has anyone seen this before?
Thanks,
Mark
sutkowy1 is offline   Reply With Quote
Old   September 8, 2022, 05:01
Default Hi Bernhard !!! Sorry for posting on an old thread...
  #23
Gaurav
Gaurav C is on a distinguished road
I am facing this problem....
openfoam2112:~/OpenFOAM/gaurav-v2112/applications/swak4Foam/
gaurav$ ./AllwmakeAll
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
Current OpenFOAM version is v2112.
Previously compiled for OpenFOAM (v2112)
/home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Looking for Python 3
Using our own Lua at /home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 202x.yy.0
hg info: 481d96f16780 (develop) tip
Using /usr/bin/bear to build compilation database
Bison: /home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
Flex is version 2.6.4 (Minor version: 4)
OpenFOAM-version: Major 2112 Minor 0 Patch 0 (-1 == x / 0) Fork: com
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
Unrecognized parameter: "--cdb=/home/gaurav/OpenFOAM/gaurav-v2112/applications/swak4Foam/compile_commands.json"
Usage: bear [--output <arg>] [--verbose] -- ...
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
gaurav$
I have followed following steps to install sak4Foam in openFOAM v2112
sudo apt install pip
pip install pyFOAM
sudo apt install mercurial
sudo apt install bison 3 or higher
sudo apt install python-is-python3
cd OpenFOAM/gaurav-v2206 mkdir applications
cd OpenFOAM/gaurav-v2206/applications hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
cd OpenFOAM/gaurav-v2206/applications/swak4Foam openfoam2206
hg update develop
./AllwmakeAll
pre { background: transparent }pre.western { font-family: "Liberation Mono", monospace; font-size: 10pt }pre.cjk { font-family: "Noto Sans Mono CJK SC", monospace; font-size: 10pt }pre.ctl { font-family: "Liberation Mono", monospace; font-size: 10pt }p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }a:visited { color: #800000; so-language: zxx; text-decoration: underline }a:link { color: #000080; so-language: zxx; text-decoration: underline }
(Few days back, I successfully installed in v2206, but now need to install on v2112 also due to some reason in the same laptop)
Last edited by Gaurav C; September 8, 2022 at 05:10. Reason: last message did not include last few sentences..
Gaurav C is offline   Reply With Quote
Old   September 8, 2022, 05:06
Gaurav
Thanks,
Mark
Hi
Although, I am also Learning OpenFOAM, BUT here I think you need to install "bear"
sudo apt install bear
after that you will face what I am facing write now, if you have solved the problem please share here. I hope it would help me, as I am also facing the same issue..
Old   September 8, 2022, 05:18
Assistant Moderator
Bernhard Gschaider
Flex: /usr/bin/flex
gaurav$
pip install pyFOAM
hg update develop
./AllwmakeAll
Thanks for providing all the necessary information to diagnose the problem
Seems that the utility /usr/bin/bear is not what the script expects (a utility that aids development by building a database of the source). Would be good to know which one to avoid that problem in the future. Could you
dpkg -S /usr/bin/bear
this should output something like
bear: /usr/bin/bear
use the package name before the colon in
apt-cache show bear
Anyway. To fix the proble temporarily remove the lines
BEARPATH=$(which bear)
if [[ $? == 0 ]]; then
    echo "Using ${BEARPATH} to build compilation database"
    export BEAR_COMPILE_PREFIX="bear --append --cdb=$(pwd)/compile_commands.json"
else
    echo "No 'bear' installed"
fi
from Allwmake. Then the compilation should work
Gaurav C likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 8, 2022, 06:10
Default Thanks Sir for the prompt response..
  #26
Gaurav
bear: /usr/bin/bear
apt-cache show bear
else
fi
I did as you suggested, it compiled for a while then stopped again.
I am overwhelmed with your fast response, but all of sudden internet is not working in the University...
Please give me some time to arrange current errors here..
Old   September 8, 2022, 06:19
Default Hi Bernhard, Please find the current status..
  #27
Gaurav
hg info: 481d96f16780+ (develop) tip
Flex: /usr/bin/flex
wmake libso swak4FoamParsers
g++ -std=c++14 -m64 -pthread -DOPENFOAM=2112 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/usr/lib/openfoam/openfoam2112/src/finiteVolume/lnInclude -I/usr/lib/openfoam/openfoam2112/src/surfMesh/lnInclude -I/usr/lib/openfoam/openfoam2112/src/sampling/lnInclude -I/usr/lib/openfoam/openfoam2112/src/fileFormats/lnInclude -I/usr/lib/openfoam/openfoam2112/src/dynamicMesh/lnInclude -I/usr/lib/openfoam/openfoam2112/src/lagrangian/basic/lnInclude -I/usr/lib/openfoam/openfoam2112/src/surfMesh/lnInclude -I/usr/lib/openfoam/openfoam2112/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2112/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/SetsRepository.C -o Make/linux64GccDPInt32Opt/repositories/SetsRepository.o
repositories/SetsRepository.C:48:22: error: ‘scalar’ was not declared in this scope; did you mean ‘Foam::scalar’?
48 | typedef Foam::writer<scalar> writerType;
| Foam::scalar
In file included from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/floatScalar.H:41,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/scalar.H:42,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/IOstream.H:52,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/Ostream.H:42,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/OSstream.H:42,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/messageStream.H:285,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/error.H:59,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/autoPtrI.H:29,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/autoPtr.H:312,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/List.H:46,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/labelList.H:45,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/UPstream.H:46,
from /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/Pstream.H:45,
from lnInclude/DebugOStream.H:50,
from lnInclude/swak.H:880,
from repositories/SetsRepository.C:33:
/usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/scalarFwd.H:63:22: note: ‘Foam::scalar’ declared here
63 | typedef doubleScalar scalar;
repositories/SetsRepository.C:48:28: error: template argument 1 is invalid
repositories/SetsRepository.C: In member function ‘Foam::sampledSet& Foam::SetsRepository::getSet(const Foam::dictionary&, const Foam:olyMesh&)’:
repositories/SetsRepository.C:182:32: error: expected unqualified-id before ‘(’ token
182 | writerType::New(format)
repositories/SetsRepository.C:182:32: error: expected ‘)’ before ‘(’ token
repositories/SetsRepository.C:181:42: note: to match this ‘(’
181 | autoPtr<writerType> theWriter(
repositories/SetsRepository.C:182:39: warning: declaration of ‘Foam::autoPtr<int> Foam::theWriter(...)’ has ‘extern’ and is initialized
repositories/SetsRepository.C:182:32: error: initializer provided for function
repositories/SetsRepository.C:201:43: error: request for member ‘getFileName’ in ‘* Foam::theWriter’, which is of non-class type ‘Foam::autoPtr<int>(...)’
201 | fileName fName(theWriter->getFileName(set, wordList(0)));
repositories/SetsRepository.C:207:28: error: request for member ‘write’ in ‘* Foam::theWriter’, which is of non-class type ‘Foam::autoPtr<int>(...)’
207 | theWriter->write(
repositories/SetsRepository.C: In member function ‘virtual bool Foam::SetsRepository::writeData(Foam::Ostream&) const’:
repositories/SetsRepository.C:278:28: error: expected unqualified-id before ‘(’ token
278 | writerType::New(format)
repositories/SetsRepository.C:278:28: error: expected ‘)’ before ‘(’ token
repositories/SetsRepository.C:277:38: note: to match this ‘(’
277 | autoPtr<writerType> theWriter(
repositories/SetsRepository.C:278:35: warning: declaration of ‘Foam::autoPtr<int> Foam::theWriter(...)’ has ‘extern’ and is initialized
repositories/SetsRepository.C:278:28: error: initializer provided for function
repositories/SetsRepository.C:288:35: error: request for member ‘getFileName’ in ‘* Foam::theWriter’, which is of non-class type ‘Foam::autoPtr<int>(...)’
288 | fileName fName(theWriter->getFileName(set, wordList(0)));
repositories/SetsRepository.C:291:20: error: request for member ‘write’ in ‘* Foam::theWriter’, which is of non-class type ‘Foam::autoPtr<int>(...)’
291 | theWriter->write(
repositories/SetsRepository.C:273:21: warning: unused variable ‘format’ [-Wunused-variable]
273 | const word &format=it();
make: *** [/usr/lib/openfoam/openfoam2112/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/repositories/SetsRepository.o] Error 1
gaurav$
Thanks in advance Sir
Old   September 8, 2022, 07:07
Gaurav
bear: /usr/bin/bear
apt-cache show bear
else
fi
Please find the results of above commands
bear: /usr/bin/bear
gaurav@hp14:~$ apt-cache show bear
Package: bear
Architecture: amd64
Version: 3.0.18-1
Priority: optional
Section: universe/devel
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Sebastian Ramacher <sramacher@debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 1160
Depends: libear (= 3.0.18-1), libc6 (>= 2.34), libfmt8 (>= 8.0.1+ds1), libgcc-s1 (>= 3.3.1), libgrpc++1 (>= 1.30.2), libprotobuf23 (>= 3.12.4), libspdlog1-fmt8, libstdc++6 (>= 11)
Filename: pool/universe/b/bear/bear_3.0.18-1_amd64.deb
MD5sum: 92fa84e3c3d6f62649fe70a401875caa
SHA1: aa2bf89276f742ac079bc4c5fcd6509d23111a62
SHA256: 27765033c333cda6eb65b11c8cd8f601ab35cca79247a33b65 5632a9d7292f2f
SHA512: b7a1fca31bd925712baa68e65d4afbf4ece64d794cbb8adb35 ab00d7dce42977d3b4f54735117baa152f0f53c68dcd6fa945 b9567ed3702028b6dc796105f8b4
Homepage: https://github.com/rizsotto/Bear
Description-en: generate compilation database for Clang tooling
Bear records the flags passed to the compiler for each translation unit and
stores them in a JSON file. This file can be used by Clang's tooling interface
and programs like clang-check to process a translation unit.
cmake supports the generation of JSON compilation databases out of the box.
For any other build system that does not support this, Bear can be used
instead to intercept the invocation of the compiler.
Description-md5: 7181645ef316f8148f4d7cc522b76bf9
Old   September 21, 2022, 05:23
Assistant Moderator
Bernhard Gschaider
bear: /usr/bin/bear
Package: bear
Architecture: amd64
Version: 3.0.18-1
Priority: optional
Origin: Ubuntu
OK. This is the right program but a newer version than mine (2.3)
Seems that they changed the parameters
Old   December 8, 2022, 06:04
Altaf lone
altaf is on a distinguished road
bear: /usr/bin/bear
Package: bear
Architecture: amd64
Version: 3.0.18-1
Priority: optional
Origin: Ubuntu
Dear Mr. Gaurav
Did you solve the problem then? i am facing exactly the same problem with foam-v2112.
altaf is offline   Reply With Quote
Old   December 10, 2022, 09:03
Default "openfoam-v2112" "swak4foam" "installation error"
  #31
Altaf lone
Dear foamers
i am trying to install swak4foam for my openfoam-v2112 but have not been able to do for a while. i am trying get this work for a week now and i am not able to do it.
my method of installation for the error message attached below is as follows
Steps for swak4Foam installation:
create run directory:
mkdir -p $FOAM_RUN
cd "$HOME/OpenFOAM/$USER-$WM_PROJECT_VERSION"
download
swak4Foam hg clone http://hg.code.sf.net/p/openfoam-exte... swak4Foam
(cd swak4Foam && hg update develop)
install
./AllwmakeAll
the error message i get is pasted below
Add /home/altaf/OpenFOAM/altaf-v2112/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
/home/altaf/OpenFOAM/altaf-v2112/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Found Python 2.7
Configuring Python 2.7
Using python2.7 at /usr/bin/python2.7-config for python2
Found Python 3.8
Configuring Python 3.8
Using python3.8 at /usr/bin/python3.8-config for python3
Using our own Lua at /home/altaf/OpenFOAM/altaf-v2112/swak4Foam/privateRequirements
Bison: /home/altaf/OpenFOAM/altaf-v2112/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/altaf/OpenFOAM/altaf-v2112/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2112 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/home/altaf/foam-2112/OpenFOAM-v2112/src/finiteVolume/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/surfMesh/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/sampling/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/fileFormats/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/dynamicMesh/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/lagrangian/basic/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/surfMesh/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -iquote. -IlnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude -I/home/altaf/foam-2112/OpenFOAM-v2112/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/SetsRepository.C -o Make/linux64GccDPInt32Opt/repositories/SetsRepository.o
| Foam::scalar
In file included from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/floatScalar.H:41,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/scalar.H:42,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/IOstream.H:52,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/Ostream.H:42,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/OSstream.H:42,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/messageStream.H:285,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/error.H:59,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/autoPtrI.H:29,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/autoPtr.H:312,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/List.H:46,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/labelList.H:45,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/UPstream.H:46,
from /home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/Pstream.H:45,
/home/altaf/foam-2112/OpenFOAM-v2112/src/OpenFOAM/lnInclude/scalarFwd.H:63:22: note: ‘Foam::scalar’ declared here
make: *** [/home/altaf/foam-2112/OpenFOAM-v2112/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/repositories/SetsRepository.o] Error 1
request help.
altaf
Old   January 2, 2023, 11:14
Eren
Once again I'm asking for your funkyAssistance...
Swak4Foam on OF2006 on my local pc works fine, but now I need to use swak4foam for my work, and again, it doesn't compile with OF2112. Error message is below, and no it does not compile with using "sudo ./AllwmakeAll" somehow using sudo overrides the OF environment... I followed your comment, and yes there is really no files but I don't know how to fix it...
[CODE]Bison already installed/compiled
Add /home/eren/OpenFOAM-v2112/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
This is a clean install
/home/eren/OpenFOAM-v2112/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Found Python 2.7
Found Python 3.6
Configuring Python 3.6
Using python3.6 at /usr/bin/python3.6-config for python3
Using our own Lua at /home/eren/OpenFOAM-v2112/swak4Foam/privateRequirements
Bison: /home/eren/OpenFOAM-v2112/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/eren/OpenFOAM-v2112/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
No swak4FoamParsers/foamVersion4swak.H. Generated
    ln: simpleFunctionObjects/lnInclude
/home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61:   /home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions:  No such file or directory
/home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:71:   /home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison:  No such file or directory
/home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:72:   /home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex:  No such file or directory
make:  *** No rule to make target  '/home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'.   Stop.
wmake  error: file  '/home/eren/OpenFOAM-v2112/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/sourceFiles'  could not be created in  /home/eren/OpenFOAM-v2112/swak4Foam/Libraries/swak4FoamParsers
Old   September 9, 2024, 08:42
Smile
  #33
Aomine17 is on a distinguished road
I'm not 100% sure if the latest release (that would be the one pulled by your command) compiles completely with your command as it was released before v2006 (I did some adaptions according to the git that would become 2006 which compile most of it)
To be sure do
hg update develop
if the released version does not compile
Hello gschaider, I have recently been working with swak4Foam and attempted to compile it with OpenFOAM v2006. I have executed the update command using:
hg update develop
or
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam -u develop
However, I still encountered an error during the compilation process. The error message is as follows:
In file included from ../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/outputFilterOutputControl.C:26:
lnInclude/swak.H:48:2: error: #error "This swak4Foam-version is only used for the 2.x-versions of OpenFOAM. For lower versions there is a special branch"
make: *** [/home/users/OpenFoam/OpenFOAM-v2006/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/outputFilterOutputControl.o] Error 1
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard.
It appears that the version of swak4Foam I am using is incompatible with OpenFOAM v2006. I would greatly appreciate any guidance or solutions you might have to resolve this issue.
Best regards.
Aomine17 is offline   Reply With Quote
openfoam-v2006, swak4foam
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[swak4Foam] Error: Installing swak4Foam into OpenFOAM 2.3.0 on CentOS 7 mushtime OpenFOAM Community Contributions 9 July 23, 2017 16:27
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
