[waves2Foam] Wave breaking occurring at H/D = 0.5 (wave height/Depth)
Like Tree1Likes
  • 1 Post By edwinrajeev
Old   June 22, 2021, 10:10
Default Wave breaking occurring at H/D = 0.5 (wave height/Depth)
Edwin Rajeev
edwinrajeev is on a distinguished road
This question is with regards to the waves2Foam solver.
I am trying to simulate wave loading on a vertical wall (2D) under large wave height conditions.
The wave properties are: H = 6.4m; D = 12.8m; Tp = 10.96s
For waves to break the criterion should be H/D>0.7 and H>1/7 (wavelength).
as you can see the H/D = 0.5 which is less than the criterion for the wave to break.
After the simulation ran, the results showed that there is wave breaking occurring from the second wave onwards. Similar trend was noticed for H/D = 0.4. At H/D = 0.3, the waves stopped breaking earlier.
The same is happening in olaFlow; interIsoFoam; waves2Foam in a simple waveFlume setup.
I am not sure what this could be attributed to? Could it be the reflection from the wall? Or is there an error in my case setup.
I have attached a short video of the simulation at H/D = 0.5.
https://drive.google.com/file/d/1EfZ...ew?usp=sharing
Link to setup files
https://drive.google.com/file/d/14Fz...ew?usp=sharing
Kindly do consider.
edwinrajeev is offline   Reply With Quote
Old   June 24, 2021, 11:45
Edwin Rajeev
Solved it.
Incase anyone wants it in the future. I was using the Stokes theory for the specified water depths. For such big and long waves, linear (airy) and solitary wave theories are optimum and robust. These theories can run such high waves.
Regards
ngj likes this.
wave breaking, wave loading, waves2foam
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) robingilbert OpenFOAM Meshing & Mesh Conversion 28 November 23, 2023 06:32
[blockMesh] blockMesh with "open" cell/face Felima OpenFOAM Meshing & Mesh Conversion 0 October 8, 2019 10:04
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 6 June 19, 2017 14:12
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 0 April 7, 2011 11:09
