[waves2Foam] is there a way to force the outlet relaxation zone theoretical? |
July 11, 2022, 06:22 |
eunchong
Rep Power: 4 |
Hello All,
I'm beginner in waves2foam and trying to create a 2D stokes 5th wave. As far as I know, the relaxation at the outlet forced to kill the waves like sponge layer.(where the velocity vector is set of 0 and based on the position of the still water level.) but what I'm trying to do is force the outlet to follow the theoretical formula as inlet relaxation zone. If anyone knows this problem, I'd really appreciate it if you could let me know. thank you. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object environmentalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // seaLevel 0.00; // A list of the relaxation zones in the simulation. The parameters are given // in <name>Coeffs below. relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { waveType stokesFifth; Tsoft 2; period 2; depth 3.5; direction (1.0 0 0); phi 0.000000; height 0.0623; stokesDrift 0.0; // Specifications on the relaxation zone shape and relaxation scheme relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0 -1 0); endX (6.5 1 0); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 2; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (33.5 -1 0); endX (40 1 0); orientation (1.0 0.0 0.0); } }; |
PIMPLE Stability | CallumG | OpenFOAM Running, Solving & CFD | 3 | July 16, 2022 04:17 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
