[swak4Foam] swak4foam building problem
Like Tree3Likes
Old   November 11, 2011, 12:36
Assistant Moderator
Bernhard Gschaider
Originally Posted by MOHAMMAD67 View Post
Dear Bernhard
my OS is opensuse 11.4.
Havn't got that.
Try adding -ltriSurface and -lsampling to Make/options and see if the problem goes away
Old   November 11, 2011, 13:02
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
sorry bernhard I don't know how to add ! where is the directory make/options? and also ltrisurface and lsampling libraries?
MOHAMMAD67 is offline   Reply With Quote
Old   November 12, 2011, 06:53
Retired Super Moderator
Bruno Santos
Greetings to all,
I had an openSUSE 11.4 x86_64 installed in a virtual machine (VM) so I had a go at it:
  1. Installed OpenFOAM 2.0.x as explained here: http://www.openfoam.org/git.php
  2. As explained in the previous link, I installed the necessary packages and also installed Python's Development packages:
    zypper install -t pattern devel_C_C++
    zypper install cmake libqt4-devel gnuplot
    zypper install python-devel
  3. A note: before running "./Allwmake", I ran:
    export WM_NCOMPPROCS=4
    This way OpenFOAM was built with all 4 CPU cores available in the VM.
  4. After OpenFOAM finished building, I went to swak4foam:
    mkdir -p $FOAM_RUN
    cd $FOAM_RUN/..
    svn checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breeder_2.0/libraries/swak4Foam/
    cd swak4Foam
  5. Create/edit the file "swakConfiguration" and wrote in it:
    export SWAK_PYTHON_INCLUDE="-I/usr/include/python2.7"
    export SWAK_PYTHON_LINK="-L/usr/lib64 -lpython2.7"
  6. To build with the latest OpenFOAM 2.0.x version I had to apply a certain patch to work (seen here):
    wget "http://sourceforge.net/apps/mantisbt/openfoam-extend/file_download.php?file_id=56&type=bug" -O swakFO_coded_bleeding_edge.patch
    patch -p1 < swakFO_coded_bleeding_edge.patch
  7. Then built "swak4foam":
    ./Allwmake > make.log 2>&1
And done! I didn't build/install ParaView since it would take a while longer to get results.
Soooo... I wasn't able to reproduce Mohammad's problem
Therefore, Mohammad, please try the instructions I've written down.
Best regards,
Bruno
Old   November 12, 2011, 07:52
Exclamation the same error even with your method
  #24
Dear wyldckat
I did step 4 to 7. but I faced the same problem as can be seen in the log file.
Old   November 12, 2011, 08:20
Bruno Santos
Hi Mohammad,
According to the log:
  • You didn't do set #6 or maybe something went wrong when you did that step.
  • Your OpenFOAM installation seems to be seriously damaged.
I advise you pull the latest version of OpenFOAM 2.0.x and rebuild it:
foam
git pull
wcleanAll
Change "4" to the number of cores/threads your machine has. The command lscpu should be able to tell this value.
And do the commands in step #2 just in case something might be missing.
Best regards,
Bruno
Old   January 16, 2012, 12:30
Hugo
Hugoles is on a distinguished road
Hi all,
I am having some problems to build swak4Foam in OF 1.6 (Ubuntu Maverick) which I can't figure out. I attach the log file.
I know that the easiest would probably be to use a newer version of OF (I actually compiled swak4Foam in OF 1.7.1, OS X 10.6.7, without problems) but our cluster has 1.6. Any experience building in OF 1.6? I have not seen threads claiming success building with OF lower than 1.6.ext .
Any help is very appreciated,
Hugo
Hugoles is offline   Reply With Quote
Old   January 16, 2012, 14:57
Assistant Moderator
Bernhard Gschaider
Originally Posted by Hugoles View Post
Hi all,
Hugo
Seems like the dictionary-class got the method subOrEmptyDict later (funny: 1.6-ext compiles without problems which once again proves that it is more advanced than one would guess from glancing at the version number).
You could try to replace that method-call with subDict (same parameter). If you're luck it will compile (you may have to insert some empty dictionaries called "value" in some parameter files) but I don't promise anything.
Another solution would be to go back to an older version of swak. The feature that breaks your compilation was introduced one or two versions back.
Old   January 16, 2012, 16:28
Hugo
Thanks Bernhard! I wish I could get this faster though, I don't understand exactly how I can change the method like you say. Could you please be more specific?
As for the older versions, after a quick check of the project page I can't find a link to older versions. Where could I get them?
Best regards,
Hugo
Old   January 17, 2012, 07:40
Assistant Moderator
Bernhard Gschaider
Filename and line are in the logfile you sent. Open the file and replace the string subOrEmptyDict with subDict and try to recompile
You're right. That is not explained. The easiest way (if you have mercurial installed) ist the following:
Clone the development repository:
hg clone http://openfoam-extend.hg.sourceforg...tend/swak4Foam
go into that directory
cd swak4Foam
List the available tags
hg tags
Try to update to one of the older releases
hg update release2011-04-20
and compile as usual. There is a similar way with the SVN-version but it is not as straightforward
elvis likes this.
Old   January 17, 2012, 15:27
Hugo
Alright, that solved the problem, thanks Bernhard. No need to use older versions.
On a side note, in the wiki page of swak, the link to your presentation at the last OF workshop is broken. Those slides have been of great source of documentation to learn how to use swak4Foam, at least for me (actually all the links to the workshop program appear to be broken in the website of the workshop). It would be a shame not to be able to see the talk anymore.
thanks for such a great tool!
Best regards,
Old   January 17, 2012, 19:32
Assistant Moderator
Bernhard Gschaider
Best regards,
Thanks for the notification about the talk. I think this is a temporary problem (the Workshop-site changed ownership as it is moving from the US of A to Germany). It was not intended as this but see it as a reminder to think about attending the next Workshop because that is where you see that kind of stuff live. It is also not affiliated to the Internet Blackout Day (at least as far as I know) and hopefully will be fixed before Wikipedia goes back online
Bernhard
PS: Greetings to Karl, the Posting Policeman, who makes sure that nothing is posted after curfew
Old   February 9, 2012, 16:35
Hugo
After solving the building problem above (thanks Bernhard), I dare to pollute this threat with a question about the use and capabilities of swak: I want to sample data from a particular region of my domain, the main problem is that sampleDict does not allow to use expressions. In my case, I want to sample a plane of a certain radius within my domain. I try to use cellSet to define a zone using an expression (thanks to the use of swakTopoSources library) but apparently the sample utility does not recognize this set definition (I know I am assuming that a Set is equal to a Zone here though, but I cannot find how to convert one into the other either).
Is there any way to do this with swak in post processing? since funkyDoCalc uses the "accumulations" entry, it seems that I cannot get the value of a variable for each cell, but only the max, min, average or sum.
any ideas? thanks,
Hugo
Old   February 9, 2012, 18:36
Assistant Moderator
Bernhard Gschaider
any ideas? thanks,
Hugo
I'm not quite sure what you want to achieve. Basically write every value in the cellSet? There is a functionObject dumpSwakExpression in simpleSwakFunctionObjects that writes ALL the values of a swak-expression to file. Note:
- this can produce huge files
- the order of the elements may be non-intuitive. Have to write for instance the cell-centers with a separate expression and join these two files to do some reasonable postprocessing
- it is not very well tested
- it does not work in parallel (I think)
BTW: about your "how do I convert a set to a zone": if I tell you that there is a utility called setsToZones how long does it take you till you shout "That's too easy"?
Old   February 10, 2012, 11:47
Thumbs up
  #34
Hugo
Well, I just want to extract the velocity field of an arbitrary region. Thanks to swak I can define that region using an expression. While I can do this during the run (with functionObjects), I can't figure out how to do it in post-processing as funkyDoCalc only gives results from "accumulations" of a field.
Anyways, I just tried defining the region of interest using an expression in cellSet, converting the set to a zone and using sampleDict with the "zone" option (I still use OF 1.6 so it also took me some time to realize that there was an ill-defined "zoneName" in the dictionary). This method works as I only needed to sample over a plane, but what if I wanted to sample over a volume? many planes? sounds to me like swak can do this (which you already answered)
Still, there is an interesting result I get when I try to obtain the average (or min, max, sum) of a field over an arbitrary region using funkyDoCalc. For example, in my funkyDoCalcDict I define:
 TKE_AV
 type      swakExpression;
 valueType cellSet;
 setName   averagingRegion;
 variables (
 "TKE{cellSet'averagingRegion}=0.5*pow(mag(U-UMean),2);"
 expression "sum(mag(TKE)*vol())/sum(vol())";
 accumulations (
 min
 verbose       true;
So when I run funkyDoCalc, I always get the message:
 Time = 66
 TKE : swak4Foam: Allocating new repository for sampledGlobalVariables
 --> FOAM Warning :
     From function ExpressionResult::getUniformInternal(const label size,bool noWarn)
     in file ExpressionResultI.H at line 158
     The minimum value 5.47109e-09 and the maximum 0.106011 differ. I will use the average 0.00403377
  max=0.00403377 min=0.00403377 average=0.00403377
 End
Note that I use UMean, which I intend to be taken as the average velocity of the previous write interval (using resetOnOutput true). However, it appears to be taken as a value that is recalculated at each time step. I am not sure if this is the cause of the message.
about 3 sec
thanks Bernhard,
Hugo
Old   February 13, 2012, 18:23
Assistant Moderator
Bernhard Gschaider
 TKE_AV
 valueType cellSet;
 variables (
 accumulations (
 min
 verbose       true;
 Time = 66
 --> FOAM Warning :
 End
That is the expected behaviour: because you wrote the variable as
the parser assumed that you're transferring the result to another entity and it can only do this uniformly (therefor the average). As you're calculating on the same entity if you write the variable as
"TKE=0.5*pow(mag(U-UMean),2);"
everything should be good.
About the UMean: that is not defined in the dictionaries you posted, is it? Therefor I won't comment on that. Have look if the change above gives you the expected behaviour
about 3 sec
thanks Bernhard,
Hugo
Seems that your reflexes are OK
Bernhard
Old   September 17, 2012, 17:51
Default dumpSwakExpression in parallel
  #36
Ganesh Vijayakumar
ganeshv is on a distinguished road
Bernhard, how can I make it work in parallel? I have about 20 cellZones or more, each about ~ 30 cells or so. I need data dumped on these cellZones to plot some profiles I need. Can you think of a way I can do this through the coded functionObject atleast?
ganesh
ganeshv is offline   Reply With Quote
Old   September 17, 2012, 19:02
Assistant Moderator
Bernhard Gschaider
One possibility would be to write out the coordinates of the cellZones (for instance using the dumpSwakExpression) and then edit them into a sampleDict where you use the cloud type with these coordinates (that would be a way to do it without programming)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 26, 2013, 10:03
Default swak4foam compilation problem
  #38
-luk- is on a distinguished road
Hello community,
I'm trying to compile swak4foam for OF2.1 on my RHEL 6.4 machine. I pasted in the log below. Has anyone of you experienced something similar? Is this message:
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionLexer.ll
the beginning of the problem or is this optional? I was able to install the 1.7 version a while ago without problems. For now we have to switch to the 1.7 environment to use swak4foam. Any ideas are very welcome.
Regards, Luk
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
/home/panek01l/OpenFOAM/Swak4Foam_2.x_release_0.2.3/Libraries
Bison is version 2.4.1
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 1 Patch -1 (-1 == x)
No swak4FoamParsers/foamVersion4swak.H. Generated
/home/panek01l/OpenFOAM/Swak4Foam_2.x_release_0.2.3/Libraries/swak4FoamParsers
/home/panek01l/OpenFOAM/Swak4Foam_2.x_release_0.2.3/Libraries/swak4FoamParsers/Make
/home/panek01l/OpenFOAM/Swak4Foam_2.x_release_0.2.3/Libraries/swak4FoamParsers/Make/linux64GccDPOpt
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file ExpressionResult/ExpressionResult.C
Making dependency list for source file ExpressionDriverWriter.C
Making dependency list for source file namedEnums/NumericAccumulationNamedEnum.C
Making dependency list for source file repositories/SurfacesRepository.C
Making dependency list for source file repositories/GlobalVariablesRepository.C
Making dependency list for source file namedEnums/LogicalAccumulationNamedEnum.C
Making dependency list for source file repositories/SetsRepository.C
Making dependency list for source file helpers/printSwakVersion.C
Making dependency list for source file ExpressionResult/StoredExpressionResult.C
Making dependency list for source file ExpressionResult/DelayedExpressionResult.C
Making dependency list for source file setsAndSurfaces/swakRegistryProxySurface.C
Making dependency list for source file setsAndSurfaces/swakRegistryProxySet.C
Making dependency list for source file FieldValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionParser.yy
Making dependency list for source file SubsetValueExpressionParser.yy
Making dependency list for source file CommonValueExpressionDriver.C
Making dependency list for source file makeSwakDataEntry.C
Making dependency list for source file FieldValueExpressionLexer.ll
Making dependency list for source file FieldValueExpressionDriver.C
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionDriver.C
Making dependency list for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionParser.yy
could not open file SubsetValueExpressionParser.tab.hh for source file SubsetValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
could not open file directMappedWallFvPatch.H for source file FieldValueExpressionLexer.ll
could not open file directMappedWallFvPatch.H for source file FieldValueExpressionParser.yy
could not open file directMappedWallFvPatch.H for source file PatchValueExpressionDriver.C
could not open file directMappedPointPatch.H for source file FieldValueExpressionParser.yy
could not open file directMappedPointPatch.H for source file FieldValueExpressionLexer.ll
could not open file directMappedPointPatch.H for source file PatchValueExpressionDriver.C
could not open file directMappedPointPatch.H for source file FieldValueExpressionDriver.C
could not open file SubsetValueExpressionParser.tab.hh for source file SampledSetValueExpressionDriver.C
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionParser.yy
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionLexer.ll
could not open file FixedValuePointPatchField.H for source file PatchValueExpressionDriver.C
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionParser.yy
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionDriver.C
could not open file ZeroGradientPointPatchField.H for source file PatchValueExpressionDriver.C
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionDriver.C
could not open file CalculatedPointPatchField.H for source file PatchValueExpressionDriver.C
could not open file CalculatedPointPatchField.H for source file FieldValueExpressionDriver.C
Making dependency list for source file plugins/CellSetValuePluginFunction.C
Making dependency list for source file plugins/CellZoneValuePluginFunction.C
Making dependency list for source file plugins/FaceSetValuePluginFunction.C
could not open file PatchValueExpressionParser.tab.hh for source file plugins/PatchValuePluginFunction.C
could not open file FieldValueExpressionParser.tab.hh for source file plugins/FieldValuePluginFunction.C
could not open file directMappedPatchBase.H for source file plugins/PatchValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
could not open file directMappedFvPatch.H for source file plugins/FieldValuePluginFunction.C
could not open file directMappedWallFvPatch.H for source file plugins/FieldValuePluginFunction.C
could not open file directMappedPointPatch.H for source file plugins/FieldValuePluginFunction.C
could not open file FixedValuePointPatchField.H for source file plugins/FieldValuePluginFunction.C
could not open file ZeroGradientPointPatchField.H for source file plugins/FieldValuePluginFunction.C
could not open file CalculatedPointPatchField.H for source file plugins/FieldValuePluginFunction.C
Making dependency list for source file plugins/FaceZoneValuePluginFunction.C
Making dependency list for source file plugins/SampledSetValuePluginFunction.C
Making dependency list for source file plugins/SampledSurfaceValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/CellSetValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/CellZoneValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceSetValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceZoneValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/SampledSetValuePluginFunction.C
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/SampledSurfaceValuePluginFunction.C
SOURCE=helpers/printSwakVersion.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt    -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/printSwakVersion.o
SOURCE=repositories/SurfacesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SurfacesRepository.o
SOURCE=repositories/MeshesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MeshesRepository.o
SOURCE=repositories/SetsRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SetsRepository.o
SOURCE=repositories/GlobalVariablesRepository.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt    -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/GlobalVariablesRepository.o
SOURCE=namedEnums/MeshInterpolationOrder.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MeshInterpolationOrder.o
SOURCE=namedEnums/LogicalAccumulationNamedEnum.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/LogicalAccumulationNamedEnum.o
SOURCE=namedEnums/NumericAccumulationNamedEnum.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/NumericAccumulationNamedEnum.o
SOURCE=ExpressionDriverWriter.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt    -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ExpressionDriverWriter.o
SOURCE=ExpressionResult/ExpressionResult.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt     -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude  -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/triSurface/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/surfMesh/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/lagrangian/basic/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ExpressionResult.o
In file included from /home/panek01l/OpenFOAM/ThirdParty-2.1.x/platforms/linux64/gcc-4.6.2/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../include/c++/4.6.2/bits/localefwd.h:42:0,
                 from /home/panek01l/OpenFOAM/ThirdParty-2.1.x/platforms/linux64/gcc-4.6.2/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../include/c++/4.6.2/string:45,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/string.H:51,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/word.H:42,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/int.H:39,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/label.H:61,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/HashTable.H:47,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/NamedEnum.H:38,
                 from namedEnums/NumericAccumulationNamedEnum.H:48,
                 from namedEnums/NumericAccumulationNamedEnum.C:37:
/home/panek01l/OpenFOAM/ThirdParty-2.1.x/platforms/linux64/gcc-4.6.2/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../include/c++/4.6.2/x86_64-unknown-linux-gnu/bits/c++locale.h:53:23: error: 'uselocale' was not declared in this scope
ressionResult/ExpressionResult.C:37:
... similar messages about uselocale ...
make: *** [Make/linux64GccDPOpt/LogicalAccumulationNamedEnum.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [Make/linux64GccDPOpt/printSwakVersion.o] Error 1
make: *** [Make/linux64GccDPOpt/NumericAccumulationNamedEnum.o] Error 1
In file included from /usr/include/stdio.h:929:0,
                 from /home/panek01l/OpenFOAM/ThirdParty-2.1.x/platforms/linux64/gcc-4.6.2/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../include/c++/4.6.2/cstdio:44,
                 from /home/panek01l/OpenFOAM/ThirdParty-2.1.x/platforms/linux64/gcc-4.6.2/lib/gcc/x86_64-unknown-linux-gnu/4.6.2/../../../../include/c++/4.6.2/fstream:43,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/OFstream.H:42,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude/writer.C:28,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/sampling/lnInclude/writer.H:207,
                 from repositories/SetsRepository.C:38:
/usr/include/bits/stdio.h: In function '__ssize_t getline(char**, size_t*, FILE*)':
/usr/include/bits/stdio.h:118:52: error: '__getdelim' was not declared in this scope
ExpressionResult/ExpressionResult.C: In member function 'void Foam::ExpressionResult::uglyDelete()':
ExpressionResult/ExpressionResult.C:216:20: warning: deleting 'void*' is undefined [enabled by default]
make: *** [Make/linux64GccDPOpt/GlobalVariablesRepository.o] Error 1
make: *** [Make/linux64GccDPOpt/ExpressionResult.o] Error 1
make: *** [Make/linux64GccDPOpt/SetsRepository.o] Error 1
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/IFstream.H:42,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/interpolationTable.C:27,
                 from /home/panek01l/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/interpolationTable.H:182,
                 from CommonValueExpressionDriver.H:50,
                 from ExpressionDriverWriter.C:39:
make: *** [Make/linux64GccDPOpt/MeshInterpolationOrder.o] Error 1
make: *** [Make/linux64GccDPOpt/SurfacesRepository.o] Error 1
make: *** [Make/linux64GccDPOpt/MeshesRepository.o] Error 1
make: *** [Make/linux64GccDPOpt/ExpressionDriverWriter.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
-luk- is offline   Reply With Quote
Old   July 29, 2013, 12:53
Assistant Moderator
Bernhard Gschaider
Originally Posted by -luk- View Post
Hello community,
Regards, Luk
<snip>
<snip>
It may not help you: this error message rings a bell but I do not remember what EXACTLY was the problem.
Anyway. The parallel calling of compilers mixes the error messages which makes it hard to analyze them. Switch of parallel compilation with
 export WM_NCOMPPROCS=1
The first question: did you use the compiler from ThirdParty to compile ANY other software than swak? Even just some HelloWorld-program? Because I think the problem you're seeing is a problem with the compiler installation
Old   July 29, 2013, 18:02
kilroy's Avatar
kilroy is on a distinguished road
Hello Bernhard,
I have a question about groovyBC.
With groovyBC, is it possible to define the wave direction and the current direction different than each other?
I am trying to model a boat traveling through waves (wave speed) with constant speed (boat speed). I want to see the performance of the boat with waves coming from different directions in different cases, so I need to define the direction of the waves and the current directions different than each other.
Is it possible to do that with groovyBC? If yes, do you know a tutorial/example that I can go through?
Thank you very much for your help in advance,
Best,
kilroy
kilroy is offline   Reply With Quote
Problem with building 3ddp UDF in Ansys FLUENT 16.2 SPH_CFD Fluent UDF and Scheme Programming 1 July 20, 2016 04:08
[swak4Foam] Foam-extend-3.2 and swak4foam...problem with link to triSurface ndev OpenFOAM Community Contributions 7 February 14, 2016 16:00
[swak4Foam] problem with a parabolic velocity profile Claudio87 OpenFOAM Community Contributions 5 May 29, 2014 09:30
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
problem simulating flow around a building xavier FLUENT 5 January 3, 2007 05:16
