[swak4Foam] numerical beach with funkySetFields?!
Old   June 15, 2011, 04:40
Default numerical beach with funkySetFields?!
maxonline's Avatar
Max
maxonline is on a distinguished road
I defined an function with funkySetFields that raise die kinematic viscosity to a higher level.
Is it possible to set the funkySetFields for the entire calculation (every timestep) ?
thanks - max
maxonline is offline   Reply With Quote
Old   June 15, 2011, 08:32
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by maxonline View Post
thanks - max
In swak4Foam there is a functionObject manipulateField that could do that (as long as the viscosity-Field is available under that name in memory). But I'm not totally sure whether this is the best way to implement a viscosity model
Bernhard
gschaider is offline   Reply With Quote
Old   June 15, 2011, 12:24
maxonline's Avatar
Max
Okay, that means that there is no way to create a numerical beach with funkySetFields?!
I have problems with the installation of swak4foam. That is why I tried it with funkySetFields.
Max
Old   June 15, 2011, 15:42
Assistant Moderator
Bernhard Gschaider
Max
It is. Depending on two things:
- the viscosity field is registered (so that swak can find it)
- it is not updated between the time you modify it and the time it is used
Both of this depends on the solver
Bernhard
Old   June 15, 2011, 16:15
maxonline's Avatar
Max
Ah okay.
I am creating waves with groovyBC and the solver is interFoam.
If I take a turbulence model and then modify the turbulent viscosity. Would that work?
Thank you
Max
Old   June 16, 2011, 09:31
Assistant Moderator
Bernhard Gschaider
Ah okay.
Depends on the turbulence model (whether it makes nut available "in memory"). With kEpsilon for instance you might get lucky
Bernhard
Old   June 17, 2011, 04:59
maxonline's Avatar
Max
okay, thank you. I will give it a try...
Max
funkysetfields, numerical beach, timestep
Wave Tank Numerical Beach Error: received a fatal signal (Segmentation fault) Shyam Kaushik Fluent Multiphase 0 November 15, 2016 13:59
Numerical Beach zhangxuan29 Fluent Multiphase 0 June 29, 2015 04:22
Numerical Beach Omran CFX 4 March 15, 2015 12:39
Numerical beach! Henry Arrigo CFX 1 December 12, 2012 15:08
transmissive BC / numerical beach colinB OpenFOAM Running, Solving & CFD 9 July 30, 2011 11:49
