libOSSpecific.o does not compile on Arch Linux
Old   April 17, 2012, 05:04
Default libOSSpecific.o does not compile on Arch Linux
Robert Sawko
AlmostSurelyRob will become famous soon enough
Dear All,
I have compiled OpenFOAM from sources on Arch Linux. However, I had a small issue and I have little confidence in the workaround I have applied.
After the first compilation I had many errors of the following type:
/usr/bin/ld: cannot find -lOpenFOAM
This is common and the error should go away on the second compilation. This was not happening.
After applying wmake on certain directories I figured out that libOSSpecific.o was missing.
What I did eventually was to copy this file from my "working" OF distribution into $FOAM_LIBBIN. The previous file was compiled on the same machine but on a different system.
My question is why did I have to do it? Why libOSSpecific.H did not compile? Is it a missing dependency? If you could provide me with some hints or references. I am a little worried that I copied an OS specific file from a different system to work on my current system.
AlmostSurelyRob is offline   Reply With Quote
Old   April 17, 2012, 05:07
Retired Super Moderator
Bruno Santos
Greetings Robert,
Apparently you're having the same problem described here: http://www.cfd-online.com/Forums/ope...oam-2-1-x.html
Best regards,
Bruno
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 04:38
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
OpenFOAM installation problem on Linux 32bit kumar OpenFOAM Installation 0 April 27, 2007 05:41
