How to install two versions of OpenFoam
Like Tree4Likes
Old   July 20, 2012, 11:56
Default How to install two versions of OpenFoam
Argen is on a distinguished road
I am trying to install a older version of OpenFOAM 1.5 to my cluster where OpenFOAM 1.7 was already installed. But I found that compiling OF 1.5 could ruin the existing OF 1.7. Any suggestion for installing OF1.5 correctly in this case?
Argen is offline   Reply With Quote
Old   July 20, 2012, 15:56
Nima Samkhaniani
nimasam is on a distinguished road
you can compile both versions and differ them by "alias" in bashrc:
example:
alias of16x='. /usr/lib/OpenFOAM-1.6-ext/etc/bashrc'
alias of211='. /opt/openfoam211/etc/bashrc'
alias of210='. /opt/openfoam210/etc/bashrc'
alias of201='. /opt/openfoam201/etc/bashrc'
elham-u, bfzah, siamak 60 and 1 others like this.
nimasam is offline   Reply With Quote
Old   July 20, 2012, 17:21
Retired Super Moderator
Bruno Santos
Greetings to all!
For more information about multiple versions: Advanced tips for working with the OpenFOAM shell environment
As for OpenFOAM 1.5: Blast from the past: installing OpenFOAM 1.5 in modern Linux boxes
Best regards,
Bruno
Old   July 23, 2012, 18:02
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks for your reply. I followed this link step by step, while gcc couldn't properly built when "./build-gcc43 > gccmake.log 2>&1 " is executed. The detailed log was attached. How to fix it?
/home/maa/OpenFOAM/ThirdParty-1.5/platforms/linux64/gcc-4.3.3/x86_64-unknown-linux-gnu/bin/ranlib libgcc.a
/home/maa/OpenFOAM/ThirdParty-1.5/platforms/linux64/gcc-4.3.3/x86_64-unknown-linux-gnu/bin/ld: cannot find -lc
collect2: ld returned 1 exit status
make[3]: *** [libgcc_s.so] Error 1
make[3]: Leaving directory `/nfs/rachel03/home01/maa/OpenFOAM/ThirdParty-1.5/platforms/build-linux64Gcc43/gcc-4.3.3/x86_64-unknown-linux-gnu/libgcc'
make[2]: *** [all-stage1-target-libgcc] Error 2
make[2]: Leaving directory `/nfs/rachel03/home01/maa/OpenFOAM/ThirdParty-1.5/platforms/build-linux64Gcc43/gcc-4.3.3'
make[1]: *** [stage1-bubble] Error 2
make[1]: Leaving directory `/nfs/rachel03/home01/maa/OpenFOAM/ThirdParty-1.5/platforms/build-linux64Gcc43/gcc-4.3.3'
make: *** [all] Error 2
Old   July 23, 2012, 18:23
Bruno Santos
Hi Argen,
I'm already too sleepy to remember where I've seen this error before and how it was fixed back then...
But still, what's the Linux distribution and version you are using on the cluster?
I've taken a look at my blog and this might be of help:
Originally Posted by http://www.cfd-online.com/Forums/blogs/wyldckat/534-gcc-other-compiler-issues-openfoam.html
On how to compile gcc-4.3.3 that comes with the ThirdParty-1.6 package - follow the posts starting on this post: OpenFoam Installation in Redhat Enterprise linux 5 post #4
Best regards,
Bruno
Old   July 23, 2012, 18:52
It's Linux version 2.6.32.28.
Old   July 24, 2012, 16:18
Bruno Santos
Hi Argen,
OK, I'm guessing then that you are using CentOS or RHEL 6.x. The error you're getting seems to be the one explained here: http://www.cyberciti.biz/faq/centos-...-findlc-error/
The fix seems to be:
Originally Posted by http://www.cyberciti.biz/faq/centos-rhel-redhat-usrbinld-cannot-findlc-error/
To install this, login as root and type the following command:
# yum install  glibc-static
Best regards,
Bruno
Old   July 25, 2012, 13:43
Hi Argen,
Hi Bruno,
It didn't work. Even yum couldn't be found as, "-bash: yum: command not found". Sorry to give your wrong version information in the previous reply. It actually is
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=11.04
DISTRIB_CODENAME=natty
DISTRIB_DESCRIPTION="Ubuntu 11.04"
In this case, how can I sort it out?
Thanks,
Argen
Old   July 25, 2012, 13:53
Bruno Santos
Hi Argen,
Ah HA! OK, simple enough:
sudo apt-get install libc6-dev
Best regards,
Bruno
Old   July 25, 2012, 14:46
Hi Argen,
Best regards,
Bruno
I got the following information after running that command. It seems the newest version is already installed.
~# sudo apt-get install libc6-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libc6-dev is already the newest version.
libc6-dev set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 30 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
Old   July 25, 2012, 14:57
Bruno Santos
Now I remember, I saw this before while I was trying to build Gcc 4.3.3 on Ubuntu 11.10. Things changed so much that a new few hacks are necessary. One such hack is this for 64bit platforms:
export LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
Then try again building Gcc 4.3.3. The source for this hack was this: http://www.lukedodd.com/?p=225
The reason why this was added is because the library moved from the usual "/usr/lib" folder. To see where the required "libc.a" is located, run:
dpkg-query -S libc.a
Old   July 25, 2012, 19:15
It looks gcc-4.3 can be installed as shown in gcc-Gcc43_make-intall.log. But, once ./Allwmake > 3rdmake_1ststage.log 2>&1 is executed for ThirdParty-1.5, some errors happened as shown in 3rdmake_1ststage.log. What's the problem?
Old   July 26, 2012, 03:43
Bruno Santos
Hi Argen,
I'll have to look into this myself. This weekend I should be able to see what I can do on my Ubuntu 11.10.
Best regards,
Bruno
Old   July 30, 2012, 01:36
Hi Argen,
Best regards,
Bruno
Hi Bruno,
Have you figured it out?
Thanks,
Argen
Old   July 30, 2012, 05:19
Bruno Santos
Hi Argen,
Sorry, I haven't had the time to look into this yet. I'll see if later today I can test this myself.
Best regards,
Bruno
Old   July 30, 2012, 15:42
Bruno Santos
Hi Argen,
OK, I've managed to find the issue for the "ThirdParty-1.5" folder, but I haven't checked yet how the main "OpenFOAM-1.5" folder is going to behave.
Anyway, the fix is this:
foam
cd wmake/rules
sed -i -e 's=/lib/cpp $(GFLAGS)=cpp -traditional-cpp $(GFLAGS)=' linuxGcc43/general
sed -i -e 's=/lib/cpp $(GFLAGS)=cpp -traditional-cpp $(GFLAGS)=' linux64Gcc43/general
Then go back to the 3rd party folder and do:
cd $WM_THIRD_PARTY_DIR
(cd metis-5.0pre2 && make realclean)
(cd ParMetis-3.1 && make clean)
(cd ParMGridGen-1.0 && make realclean)
Do not worry about the errors that occur with Scotch, because OpenFOAM 1.5 doesn't even use Scotch!
I'll test the main OpenFOAM-1.5 next and update this post (or post a new one) when it finishes.
edit: OK, tested it successfully! I've added another version of the shell script that helps with the whole process, back in my blog post Blast from the past: installing OpenFOAM 1.5 in modern Linux boxes
If you don't want to use the script, then I advise you to update the environment variables once before each Allwmake you execute. Example for the main build:
of15
./Allwmake > make.log 2>&1
Where of15 is the alias set-up in "~/.bashrc".
Best regards,
Bruno
Old   August 6, 2012, 12:39
Thanks a lot, Bruno. When I cleaned ParMGridGen-1.0, I got the following error. Anything I missed?
:~/OpenFOAM/ThirdParty-1.5$ cd ParMGridGen-1.0 && make realclean
(cd MGridGen ; make realclean )
make[1]: Entering directory `~/OpenFOAM/ThirdParty-1.5/ParMGridGen-1.0/MGridGen'
(cd IMlib ; gmake realclean )
/bin/sh: gmake: not found
make[1]: *** [realclean] Error 127
make[1]: Leaving directory `~/OpenFOAM/ThirdParty-1.5/ParMGridGen-1.0/MGridGen'
make: *** [realclean] Error 2
Hi Argen,
foam
cd wmake/rules
of15
Best regards,
Bruno
Old   August 7, 2012, 06:26
Bruno Santos
Hi Argen,
I see that gmake came back to haunt us Here's what I wrote about it and respective fix several months ago:
The error associated to gmake is an ironic error: gmake stands for GNU make, which is the version usually packed with Linux distributions and always named as make. So, the simplest fix is to make a symbolic link of gmake to make; a simple non-root way to do this is:
ln -s `which make`  $WM_PROJECT_DIR/bin/gmake
This should create a symbolic link of make to the link gmake in OpenFOAM's bin folder.
Best regards,
Bruno
Old   August 8, 2012, 18:28
Hi Argen,
Best regards,
Bruno
Thanks for your help, Bruno. It works to clean ParMGridGen. But there's still some problem while compiling Third-party as follows. I check "which gcc, g++, make", and it shows "~/OpenFOAM/ThirdParty-1.5/platforms/linux64/gcc-4.3.3/bin/gcc, g++, make". Any idea for this problem?
Start ThirdParty Allwmake
Compile specific mpi libraries
have OPENMPI shared library
Build Scotch decomposition library
have scotch shared libraries
Build PTScotch decomposition library (requires MPI)
have ptscotch shared libraries
Build Metis decomposition
+ cd metis-5.0pre2
+ cpMakeFiles metis
+ set +x
+ wmake libso GKlib
g++: no input files
make: *** [libNULL.so] Error 1
+ wmake libso libmetis
g++: no input files
Build ParMetis decomposition. Requires MPI.
+ cd ParMetis-3.1
+ cpMakeFiles ParMetis
+ set +x
+ wmake libso METISLib
g++: no input files
+ wmake libso ParMETISLib
g++: no input files
Build ParMGridGen
+ cd ParMGridGen-1.0
+ cpMakeFiles ParMGridGen
+ set +x
+ wmake libso MGridGen/IMlib
g++: no input files
+ wmake libso MGridGen/Lib
g++: no input files
Done ThirdParty Allwmake
Old   August 9, 2012, 05:55
Bruno Santos
Hi Argen,
Nothing to worry about. As I described in the script:
#build 3rd party first, due to a strange bug regarding OpenMPI...
echo "Building ThirdParty, 1st stage, no monitoring needed..."
#lets fly to the Thirdparty-1.5 dir and fix a few things
You can now move on to running Allwmake in "OpenFOAM-1.5". Those other libraries will be built as intended.
Best regards,
Bruno
Can't get older versions of OpenFOAM fabioc OpenFOAM Installation 4 February 7, 2012 09:13
for every member help me please to install OpenFOAM dima133 OpenFOAM Installation 1 January 8, 2012 16:36
how to install openfoam on ubuntu 1.4 ? seyedashraf OpenFOAM Installation 8 August 23, 2011 05:50
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 04:06
