how to use paraview-3.14 on OpenSUSE 12.2 with OpenFOAM-2.1.x? |
September 26, 2012, 08:12 |
Pei-Ying Hsieh
Rep Power: 18 |
Dear OpenFOAMers,
Is there a way to use Paraview-3.14 with OpenFOAM-2.1.x on OpenSUSE 12.2? I downloaded the binary version, but, whenever I tried to run the binary version on OpenSUSE 12.2 (64 bit), I got "segmentation fault". Any suggestion? Pei-Ying |
October 2, 2012, 16:59 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Pei-Ying,
I didn't see this thread of yours where you had placed it, namely at the sub-forum for post-processing. I've moved the thread to here to the installation sub-forum. As for using the pre-built ParaView 3.14.1 in openSUSE 12.2:
Best regards, Bruno PS: I think I've seen a thread of yours on the ParaView mailing list (this one) and I noticed that you haven't specifically mentioned that you were using Qt 4.8.1, which would be the reason why you're getting the errors mentioned on that thread at the mailing list.
October 2, 2012, 18:39 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Bruno,
Thanks! I ended up compiling the paraview.3.14.1 from source and used the patch posted by Pablo. OpenSUSE came with QT 4.8.1. I do not know how to downgrade to QT 4.6. But, compiling from source with the patch worked on opensuse 12.2, though. Apparently the paraview team is aware of the stl ASCII issue. A fix is under review. But, I still have no clue why I cannot run the paraview development version compiled on opensuse 12.2. Pei-ying |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
Velocity vector data in OpenFOAM and ParaView mismatch | tekky | OpenFOAM | 9 | December 21, 2009 11:26 |
OpenFOAM 15 with ParaView 340 on OpenSuSE 110 | zairja | OpenFOAM Installation | 7 | February 10, 2009 08:31 |
Paraview problem on OpenSuse | gizmo | OpenFOAM Installation | 13 | December 14, 2008 03:09 |
