Error when run paraView
Old   April 1, 2013, 17:10
Default Error when run paraView
honvu is on a distinguished road
Can you help me.
Affter I installed OpenFOAM and run paraView result follow:
hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam
created temporary 'cavity.OpenFOAM'
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Main Controls" under id 64
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Selection Controls" under id 65
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "VCR Controls" under id 66
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Current Time Controls" under id 67
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Active Variable Controls" under id 68
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Representation Toolbar" under id 69
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Camera Controls" under id 70
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Center Axes Controls" under id 71
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Macros Toolbars" under id 72
When i closed terminal and return open terminal, run OpenFOAM result follow:
hon@hon-ubuntu:~$ cd OpenFOAM/hon-2.1.0/run/tutorials/
basic/ DNS/ incompressible/ resources/
combustion/ electromagnetics/ lagrangian/ stressAnalysis/
compressible/ financial/ mesh/
discreteMethods/ heatTransfer/ multiphase/
hon@hon-ubuntu:~$ cd OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity
hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ blockMesh
blockMesh: command not found
paraFoam: command not found
honvu is offline   Reply With Quote
Old   April 1, 2013, 18:07
Retired Super Moderator
Bruno Santos
Greetings honvu and welcome to the forum!
Two questions:
  1. Which Ubuntu version are you using?
  2. Which installation instructions did you follow for installing OpenFOAM 2.1.0?
Best regards,
Bruno
Old   April 1, 2013, 20:26
Two questions:
Best regards,
Bruno
Thanks Bruno.
I using Ubuntu 11.10 and installed OpenFOAM 2.1.0. When i remove OpenFOAM 2.1.0 and installed OpenFOAM 2.2.0 result the same.
Old   April 2, 2013, 15:52
Bruno Santos
Hi honvu,
I think that the messages that start with:
can be ignored. If you don't see ParaView window appear, then look at the bar on the left with all of the icons and check if there are any new icons there (I'm assuming you have the default Ubuntu interface).
As for the problem with OpenFOAM not working when you start a new terminal, that is because you probably did not add the following line to the file "~/.bashrc":
source /opt/openfoam210/etc/bashrc
This is explained in the section "User Configuration" of the official "Ubuntu Deb Pack Installation" guide: http://www.openfoam.org/download/ubuntu.php
If you have more than one line inside the file "~/.bashrc" that is related to OpenFOAM, then you should comment out the other versions, at least until you are more familiar with OpenFOAM and how it works.
Best regards,
Bruno
Old   April 3, 2013, 15:11
Hi honvu,
Best regards,
Bruno
Thanks Bruno.
I installed successful OpenFOAM for your help.
[OpenFOAM] Questions about Paraview to show Parallel run of OpenFOAM padian ParaView 20 September 24, 2018 12:52
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 10:16
paraview doesn't run after upgrading to jaunty lions85 OpenFOAM 8 June 24, 2009 17:49
Paraview run problem ztdep OpenFOAM 1 April 21, 2009 02:52
