December 30, 2013, 10:33 |
bashrc error for OpenFOAM-1.6-ext
ok
Dear foamers,
I worked in two versions of OpenFOAM (OF-2.2.2 and OF-1.6-ext). They were working fine. But the problem that I faced two days ago was with OF-1.6-ext bashrc, when I started terminal with aliasis of16ext directly it gives me this error bash: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc: No such file or directory I tried to change it many times. The aliasis of222 works fine but the problem with of16ext. I got this problem after I tried to install foam-extend-3.0. Even I commit # source $HOME/OpenFOAM/foam-extend-3.0/etc/bashrc. The problem is still there. I didn't change anything in bashrc file. My bashrc file is attacled. Regards |
December 30, 2013, 10:36 |
ok
Sorry, I got error in attachement. Anyway, this is my bashrc file
# ~/.bashrc: executed by bash(1) for non-login shells. # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything [ -z "$PS1" ] && return # don't put duplicate lines in the history. See bash(1) for more options # ... or force ignoredups and ignorespace HISTCONTROL=ignoredups:ignorespace # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt #force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if [ -f /etc/bash_completion ] && ! shopt -oq posix; then . /etc/bash_completion fi # enable autocomplete in gnuplot alias gnuplot="rlwrap -a -c -b\"\\\"\\\"\\\'\\\'\" gnuplot" # source /opt/openfoam222/etc/bashrc # source $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc alias of222='. /opt/openfoam222/etc/bashrc' alias of16ext='. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc' alias paraFoam='paraFoam -builtin' # source /home/maimouna/OpenFOAMExt/OpenFOAM-1.6-ext/etc/bashrc # /home/maimouna/OpenFOAMExt/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b # export PV_PLUGIN_PATH=/opt/openfoam210/platforms/linux64GccDPOpt/lib/paraview-3.12 # source $HOME/OpenFOAM/foam-extend-3.0/etc/bashrc Last edited by wyldckat; December 30, 2013 at 11:17. Reason: Added [CODE][/CODE] |
December 30, 2013, 11:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Bruno
December 31, 2013, 05:48 |
ok
Dear Bruno,
1. to install foam-extend-3.0, I followed steps given in http://openfoamwiki.net/index.php/Installation/Linux/foam-extend-3.0/Ubuntu#Ubuntu_12.04 2. Yes, the folder "/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext" still exists, but not working. It gives error that posted in #1. Regards |
December 31, 2013, 13:27 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
I think you caught the instructions while I was still preparing them. At the beginning of the instructions there was a warning text indicating that the instructions were still being written And it's possible that you followed the instructions without working on a new terminal with a clean environment, which could have lead to the damaged installation. Right now, the instructions for foam-extend-3.0 are finished and tested, although I still am going to do some adjustments to them. But you can already follow them now: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04 By the way, does this file exist: Code:
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc Best regards, Bruno
January 1, 2014, 09:12 |
ok
Dear Bruno,
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc exists. I committed Code:
# source /home/maimouna/foam/foam-extend-3.0/etc/bashrc Code:
bash: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc: No such file or directory. Code:
# ~/.bashrc: executed by bash(1) for non-login shells. # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything [ -z "$PS1" ] && return # don't put duplicate lines in the history. See bash(1) for more options # ... or force ignoredups and ignorespace HISTCONTROL=ignoredups:ignorespace # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt #force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if [ -f /etc/bash_completion ] && ! shopt -oq posix; then . /etc/bash_completion fi # enable autocomplete in gnuplot alias gnuplot="rlwrap -a -c -b\"\\\"\\\"\\\'\\\'\" gnuplot" # source /opt/openfoam222/etc/bashrc # source $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc alias of222='. /opt/openfoam222/etc/bashrc' alias of16ext='. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc' alias paraFoam='paraFoam -builtin' # source /home/maimouna/OpenFOAMExt/OpenFOAM-1.6-ext/etc/bashrc # /home/maimouna/OpenFOAMExt/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b # export PV_PLUGIN_PATH=/opt/openfoam210/platforms/linux64GccDPOpt/lib/paraview-3.12 # source $HOME/OpenFOAM/foam-extend-3.0/etc/bashrc # source /home/maimouna/foam/foam-extend-3.0/etc/bashrc source /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc Many thanks for your help. Last edited by wyldckat; January 1, 2014 at 09:25. Reason: Added [CODE][/CODE] |
January 1, 2014, 09:35 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Just a little note first: please post code using the "[CODE]" markers, as explained in one of the links in my signature. OK, now let's fix one problem at a time:
Best regards, Bruno
January 2, 2014, 10:03 |
ok
Hi Bruno,
when I run fe30, it gives Code:
maimouna@maimouna-desktop:~$ fe30 Sourcing: /home/maimouna/foam/foam-extend-3.0/etc/settings.sh Environment variables defined for OpenMPI: OPENMPI_BIN_DIR : /usr/bin OPENMPI_LIB_DIR : /usr/lib/openmpi/lib OPENMPI_INCLUDE_DIR : /usr/lib/openmpi/include /usr/lib/openmpi/include/openmpi OPENMPI_COMPILE_FLAGS : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread OPENMPI_LINK_FLAGS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl MPI_HOME : /usr MPI_ARCH_PATH : /usr OPAL_PREFIX : /usr PINC : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread PLIBS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt/etc/mesquite-2.1.2.sh MESQUITE_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/metis-5.1.0/platforms/linux64Gcc46DPOpt/etc/metis-5.1.0.sh METIS_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/metis-5.1.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/parmetis-4.0.3/platforms/linux64Gcc46DPOpt/etc/parmetis-4.0.3.sh PARMETIS_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/parmetis-4.0.3/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt/etc/ParMGridGen-1.0.sh PARMGRIDGEN_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt/etc/libccmio-2.6.1.sh LIBCCMIO_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/scotch-6.0.0/platforms/linux64Gcc46DPOpt/etc/scotch-6.0.0.sh SCOTCH_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/scotch-6.0.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/cmake-2.8.12/platforms/linux64Gcc46DPOpt/etc/cmake-2.8.12.sh CMAKE_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/cmake-2.8.12/platforms/linux64Gcc46DPOpt M4_DIR is initialized to: BISON_DIR is initialized to: FLEX_DIR is initialized to: ZOLTAN_DIR is initialized to: PYTHON_DIR is initialized to: Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch/etc/PyFoam-0.6.1.sh PYFOAM_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/hwloc-1.7.2/platforms/linux64Gcc46DPOpt/etc/hwloc-1.7.2.sh HWLOC_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/hwloc-1.7.2/platforms/linux64Gcc46DPOpt QT_DIR is initialized to: /usr Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParaView-4.0.1/platforms/linux64Gcc46DPOpt/etc/ParaView-4.0.1.sh PARAVIEW_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParaView-4.0.1/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/etc/aliases.sh maimouna@maimouna-desktop:~$ I attached env16ext.log.gz file. Warm regards Maimouna Last edited by wyldckat; January 2, 2014 at 18:38. Reason: missing [/CODE] |
January 2, 2014, 15:06 |
ok
Dear Bruno,
foam-extend-3.0 works fine itself. But, when I run fe30, I face problem with paraview Code:
maimouna@maimouna-desktop:~/foam/foam-extend-3.0/tutorials/incompressible/icoFoam/cavity$ paraFoam unknown option/argument: '-builtin' usage: paraFoam [OPTION] options: -case dir specify alternative case directory -region name specify mesh region name -touch only create the .foam or .foam file -nativeReader use the paraview native reader for OpenFOAM * start paraview with the OpenFOAM libraries maimouna@maimouna-desktop:~/foam/foam-extend-3.0/tutorials/incompressible/icoFoam/cavity$ http://www.cfd-online.com/Forums/blo...-openfoam.html but the error still there. Also, I tried to install Ubuntu paraview Code:
sudo apt-get paraview Many thanks in advanced. |
January 2, 2014, 18:44 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Regarding foam-extend 3.0 - try these commands, which will modify the internal option for extend's paraFoam: Code:
foam sed -i -e 's=nativeReader=builtin=g' bin/paraFoam Regarding 1.6-ext: I'm sorry to say, but it seems that the installation of 1.6-ext is too damaged. You'll have to reinstall it again. Nonetheless, since you now have got foam-extend 3.0 working, I think that you no longer need 1.6-ext. Best regards, Bruno
January 6, 2014, 10:56 |
#11 |
ok
Dear Bruno,
many thanks for your reply. At the mean time, I'll work on foam-extend 3.0. I applied foam sed -i -e 's=nativeReader=builtin=g' bin/paraFoam but still doesn't give me any positive result. Warm regards |
January 13, 2014, 05:28 |
#13 |
ok
Dear Bruno,
yah, I did what you posted before foam sed -i -e 's=nativeReader=builtin=g' bin/paraFoam but by typing mistake, they are coming in the same line. I did that two commands in two separated lines. Anyway, that is not solve the problem yet. Even, paraFoam in fe30 alias give me the following error [QUOTE]bash: /home/maimouna/home/maimouna/foam/ParaView-3.10.1-Linux-x86_64/bin/paraview: No such file or directory[/QUOTE] How can I solve that please? Many thanks in advanced. |
January 13, 2014, 17:27 |
#14 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Something isn't right. The fe30 alias is associated to foam-extend-3.0, for which it should be using ParaView 4.0.1, not ParaView 3.10.1. Try this:
Bruno
January 14, 2014, 04:46 |
#15 |
ok
Dear Bruno,
the following shows what did I get in my terminal by following that previous four steps Code:
maimouna@maimouna-desktop:~$ paraFoam bash: /home/maimouna/home/maimouna/foam/ParaView-3.10.1-Linux-x86_64/bin/paraview: No such file or directory maimouna@maimouna-desktop:~$ fe30 Sourcing: /home/maimouna/foam/foam-extend-3.0/etc/settings.sh Environment variables defined for OpenMPI: OPENMPI_BIN_DIR : /usr/bin OPENMPI_LIB_DIR : /usr/lib/openmpi/lib OPENMPI_INCLUDE_DIR : /usr/lib/openmpi/include /usr/lib/openmpi/include/openmpi OPENMPI_COMPILE_FLAGS : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread OPENMPI_LINK_FLAGS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl MPI_HOME : /usr MPI_ARCH_PATH : /usr OPAL_PREFIX : /usr PINC : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread PLIBS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt/etc/mesquite-2.1.2.sh MESQUITE_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/metis-5.1.0/platforms/linux64Gcc46DPOpt/etc/metis-5.1.0.sh METIS_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/metis-5.1.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/parmetis-4.0.3/platforms/linux64Gcc46DPOpt/etc/parmetis-4.0.3.sh PARMETIS_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/parmetis-4.0.3/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt/etc/ParMGridGen-1.0.sh PARMGRIDGEN_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt/etc/libccmio-2.6.1.sh LIBCCMIO_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/scotch-6.0.0/platforms/linux64Gcc46DPOpt/etc/scotch-6.0.0.sh SCOTCH_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/scotch-6.0.0/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/cmake-2.8.12/platforms/linux64Gcc46DPOpt/etc/cmake-2.8.12.sh CMAKE_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/cmake-2.8.12/platforms/linux64Gcc46DPOpt M4_DIR is initialized to: BISON_DIR is initialized to: FLEX_DIR is initialized to: ZOLTAN_DIR is initialized to: PYTHON_DIR is initialized to: Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch/etc/PyFoam-0.6.1.sh PYFOAM_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/hwloc-1.7.2/platforms/linux64Gcc46DPOpt/etc/hwloc-1.7.2.sh HWLOC_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/hwloc-1.7.2/platforms/linux64Gcc46DPOpt QT_DIR is initialized to: /usr Sourcing: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParaView-4.0.1/platforms/linux64Gcc46DPOpt/etc/ParaView-4.0.1.sh PARAVIEW_DIR is initialized to: /home/maimouna/foam/foam-extend-3.0/ThirdParty/packages/ParaView-4.0.1/platforms/linux64Gcc46DPOpt Sourcing: /home/maimouna/foam/foam-extend-3.0/etc/aliases.sh maimouna@maimouna-desktop:~$ paraFoam bash: /home/maimouna/home/maimouna/foam/ParaView-3.10.1-Linux-x86_64/bin/paraview: No such file or directory maimouna@maimouna-desktop:~$ |
January 16, 2014, 15:10 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Something very strange is going on... OK, try these commands and tell me what they give you: Code:
which paraFoam alias paraFoam Best regards, Bruno
January 17, 2014, 06:03 |
#17 |
ok
Dear Bruno,
many thanks for your reply. To avoid all that problem that I found, I remove foam directory which contains foam-extend-3.0 Code:
sudo rm -rf foam I didn't go back to OpenFOAM-1.6-ext at the mean time because I think foam-extend-3.0 more general with all important tutorials that I need at least thesedays. Best regards |
OpenFOAM 1.6 ext | fportela | OpenFOAM Installation | 11 | December 26, 2013 18:55 |
[mesh manipulation] difference in 'make axial mesh' for OF 2.1 & OF 1.6 EXT | Rocky4 | OpenFOAM Meshing & Mesh Conversion | 0 | November 17, 2012 16:48 |
Solver Compiling error - OF 1.6 ext. | raditz | OpenFOAM Programming & Development | 8 | November 4, 2012 09:53 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 09:38 |
installing OF 1.6 ext | yhaomin2007 | OpenFOAM Installation | 3 | September 11, 2012 16:52 |
